80FoxCoupe
My engine builder stated when sleeving my 2020 predator block, that the cylinder wall thickness was noted to be thicker than 18up gt. They may have recorded that data, but i did not ask about it.It has forged pistons....vs cast...it also has ( similar to 4th gen aluminum LS ) bulkhead supports for those plasma bores and while they are 5.2L id be curious to know since the block is rated for 12psi stock if they are slightly thicker. However supporting them in key places (kind of like people would do on the Gen 2 in the coolant jacket which to a lesser degree was introduced into the design of the gen 3 )...
Also it would be the hand built nature of them vs being at the mercy of batches of bores being a bit large coupled with piston batches being a big narrower ), this is probably regardless of break in the most significant variable in IF and when your Gen 3 starts ticking...how by pure luck tight was your batch of piston skirt thickness opposed to blocks mass produced bore thickness....
If I am being fair the Predator has not only difference in block support and forged piston but more precise repeatable hand built assembly.....
Just going off my experiences its a settled issue for me, it's funny even to this date AL, simply put a forged piston in his plasma bore block replacement ( his stock was a fairly robust ticker till it broke several secondary ring lands, like all mine did ) to this date he doesn't have the tick after countless passes and dyno pulls...still on 93 with ALL the same heads,GDI, and timing components in place...he simply took his blown stock short block out....replaced it with a stock gen 3 plasma block ( $1000 ready to assemble not a bad price honestly with final honing ready to assemble and no machine work needed ) which has 2618 forged pistons same bore.....no tick....
I been trying to research the average mass produced gen 3 rod side clearance too, as with composite pans that's amplifying anything down there...and my first engine I swear it would be louder half way up a pair of car ramps and I don't mean acoustically transmitting better I mean with directional mics......
Ford could buy a bulk 4032 piston shove it in there tight with like a perfect skirt break in coating and be golden, it's overall imho a good engine...stellar even.....they revised the balancer and need a slight revision on the intake phasers ( some of that is low oil pressure on 5w20 with the oil pressure bypass open at idle)...
If I were to buy one today new I'd factor in building a spare short block, and or buy the longest extended warranty I could and not modify it...also some dexos 2 LSPI resistant oil......
I hope I live long enough to see some of these in the 150k mile range....this will sound like bullshit but I swear I've pulled MANY 6.0L LS down at 180-230k and it still have factory hone marks in the cylinders...( LS2/3 ect LQ4s not the newer LTs).....
I think Ford tried to and for the most part made a masterpiece it's how they pretend all ticks are created equal thats bothersome...ive seen what I call 20fters ( my first engine) to dude your being anal that could be exhaust pulses but they pile all noise complaints under 7718 instead of diagnosing them individually....
Having owned the SAME car with both a LOUD one and a super quite one, I can tell how the ownership experience is vastly different and shouldn't be lumped together...thats my rub....I love how they tried to push envelopes its in my nature......
