sk47
- Nov 12, 2020
- North Eastern TN
- Jeff
- Chevy Silverado & Nissan Sentra SE
Hello; Yes, while my understanding is limited I do get there are different families of engines. The GEN III Coyote V-8's in the newest Mustangs and F-150's do share the plasma arc linings (sleeves) with these other engines.The subject engine in that link is the Voodoo in the GT350, not a Coyote ... they are two different animals so to speak.
From what I have read the plasma arc sleeve process was used first in the more high performance engines for a number of years, maybe ten years, before being used in the Coyote engines around 2018. So now the Coyote and the Voodoo share the thin cylinder liner is a point to me. I do not yet have a viable personal opinion about the process since I do not have experience working on them.
As a member pointed out in another thread, only Ford has the good numbers with regard to the engine problems or failure percentages and so far they must be keeping those numbers to themselves.
Might be the case the failures discussed in this and other threads represent only a very small percentage of the total number of such engines on the street. That would be good to know if true, then the rest of us could relax a bit.
For some reason there is a lot of discussion about engine failures. The discussions may be unfounded. I just do not know and so far such discussions appear to be the only source we have until Ford has a say. The example for me was back a few months when I was about to plunk down some money for a 2019 F-150. I did not put too much credence in the typical web chatter until I ran across a Ford technical service bulletin about the excessive oil consumption in the F-150 V8's. That TSB made the oil consumption a real issue. Later on I ran across the plasma cylinder lining discussions.
At this point the better source, from my point of view, are those people who have had these engines apart. They have had an actual look-see inside the engines in question. I, for one, will not quickly dismiss the opinions of those who have done the work.
But yes, I get that distinctions exist between the Coyote and Voodoo engines. I was thinking they had some things in common that may affect both in similar ways. I very well may be wrong in such thinking. Apologies if I have made a fundamental error.
