Fuel System Help/Advice
Zrussian13
Phoenix
I'm debating just buying the boost controller. I probably ill because I like the idea of being able to turn it down also. Installing it seems pretty straight forward too.
You can't really turn it down, only up. But that's why I run the smaller wg springs. I can cruise around at 6lbs or turn it up with the pushing a button. Plus if you set it right boost hits faster. The boost controller is great but getting the kit dialed in first might be the way to go with a used kit. Once it's set adding the boost controller is a piece of cake.
5.0_Lojos
Miami FL
Carlos
2016 Mustang GT Premium
Hello fellow mustang people,
Some background info first. I have a 2016 mustang GT and had the rare opportunity to purchase a secondhand hellion sleeper turbo kit for pretty cheap. It has the standard 62 T4 turbo and 4 into 1 hellion headers.
I plan on just running the 9 PSI spring in the waste gate and target is 700-750RWHP, which after more research, seems pretty doable with this kit. I’ll be happy with those numbers for a streetcar. The turbo kit I have no issues with as I’m very mechanically inclined and can get that going no problem. I also wanted to add I called Hellion and they were amazing with support and sent instructions, checklists, and info to help me on my journey. So far they have really impressed me.
Where I need help is the fuel side. I’m totally lost with the fuel system and what I would need for this setup. I’ve done extensive research into it, and it seems everyone agrees (for the most part) on the Fore Innovations fuel system. Ok great. So, I head to their website, which was easy to understand but then I’m quickly lost again. There is a dual pump, triple pump, L1, L2, L3, L4….. To make matters worse there is multiple pumps available to choose from. I have no idea. I tried to research but it’s hard because everyone’s situation is different and unique to their setup and # number. I couldn’t find anything for my goals of 9 PSI on 62 mm and not even sure where that would net me RWHP wise. I would like to stay pump as E85 is a hassle to get here and a 45 min drive but I would also like to keep the option open for the future if I maybe wanted to mess around with it down the road. After further research I’m confident a dual pump setup would be ok for me but which one? L1 / L2 / L3 / L4? And what pumps?
The injectors were a little easier. I did a lot of research there and everyone (agrees for the most part) that the ID1050X’s are good go to for power adders. They also seem to be a plug and play upgrade with tuning of course.
Anyways, can someone with a bit more knowledge than me please help!! I plan on getting this remote tuned with Palm Beach Dyno as everyone I’ve talked to has recommended them.
I think PBD is getting ready to come out with a Fuel System. I believe they have fuel rails in the works.
engineermike
La
2018 GTPP A10
9psi, 700whp on pump gas? If so all you need is a bap and injectors. No crazy fuel system unless you want to run E. I put 784 to the wheels on 10lbs with just a bap and dw95s.
This. Nothing further is needed. I even take a step back and say 38# injectors are all that’s needed for this boost level on gasoline.
KPM Fuel Systems
Adelaide
David
FN Mustang
Reading you post , we can recommend our KPM1000 HP as the perfect fuel system for your stated 750 rwhp on pump fuel set up.
The KPM Fuel system is a direct 20 min replacement. No hassle, No fuss, perfect OE manners.
The advantages over many of the other systems on the market -
  • Works perfectly with the OE FPCM meaning it will ramp up and down as power is needed due to being controlled by the factory computer.
  • Comes with a proper fuel bucket that incorporates 4 venturis - meaning you can run/ race the car perfectly down to a near empty fuel tank
  • Direct feed fuel system as per factory. No unnecessary return lines or clumsy add-ons.
  • Eliminates the stop gap solution of OVER-RUNNING the fuel pumps with a BAP.
  • Fuel keeps cool and dense making for most efficient power
  • No surge on long left hard corners or sweepers
  • Direct fit Add-On kits available for future power increases requiring a larger fuel system all the way up to 2700hp!
  • No extra tuning required . Fit and forget
    20 mins fitment time.
  • OE quality, performance and fitment.
All in stock and available from Beefcake Racing direct.
KPM Fuel Systems
Nothing Comes Close!
J17GT
IL
2017 Mustang GT PP
For what it's worth, my 2017 car with an out of the box Whipple gen5 3.0 stage 2 kit at 11# of boost made right on 700rwhp on the whipple tune. Only fuel system upgrade was the larger injectors that came with the kit. I think they were DW 72s.
No reason to overcomplicate this with running 93 fuel.
Vandor
New Jersey
Thomas
Thanks guys this is all great info
5.0_Lojos
Miami FL
Carlos
If u can resist the temlt
If you can resist the temptation of staying satisfied you are golden and a very smart man šŸ™Œ props to you. Never been in a whipple and bought my car with a procharger so my fun is on top and for a brief second or two šŸ¤·ā€ā™‚ļø im sure that whipple is fun.
J17GT
IL
2017 Mustang GT PP
Not a chance! Now on a e85 and have turned up the boost!! 😁
