Fuel rail feed: y block vs tee
Grimreaper
Dallas
2017 GT
Any insight or experience on pressure loss/ flow imbalance running a tee attached directly to one fuel rail vs y block feeding both? Ok or not ok to do? Expecting a system under pressure to flow bit different here.
Going to run dead headed with 10an from pump to rails. Was planning to y block to dual 8an to feed each rail in the rear with 6an balance tube across the front. A tee would simplify and shorten the fuel lines after the 10an feed though and clean up install. Would not be fed from the center of the tee, rather fed from one side.
Tee location and orientation in red.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
use whatever is most convenient. They flow rate is the same as long as the ID are the same.
Angrey
Coral Gables
2016 GT350
At pressures and flow rates associated with Ethanol or gasoline, you won't be able to measure the difference. A Y junction does have less head loss, but for the purposes of the fuel system, you won't notice a difference. Furthermore, different Y blocks and T blocks have different internal layouts so they're not all internally what you would imagine.
illtal
This is a dead head with a balance loop, I actually think just a Y block with a run to both rails would suffice.
The pressure is the same after the FPR in this kind of setup.
