TGGT
So back when I put the procharger on I modified the stock rail with an additional feed. When my tuner tuned my car the logs showed I was dropping to 43ish psi between 7300 - 8k. I decided to try one more thing for these stock rails before ponying up the dough for some aftermarket’s. I basically cut the rails in half making for two separate rails. I then flared the tubing going into the rails adding a tube nut and collar to both sides. I re flared the factory feed line for a factory style connector, and I’m using it for the return to the regulator as well as to feed the di pump. I’m not totally sure what if any difference this will make but I will say I did a fourth gear pull on the way home and the a/f was supper rich 7.2-7.4. Hopefully I can get my tuner to data log it this week. I’m super curious if it’s still dropping pressure.
