Front tires - inner edges down to cords
sk47
North Eastern TN
Jeff
Hello; I agree with others that toe is the likely cause especially with the photos.
I do not know if the tires are square or staggered on your car. If square a rotation ought to get some more mileage.
John S
Novi, Michigan
2022 Mach 1 HP
Never realized how critical toe setting was. I modified lower control arms on a Subaru and got the alignment settings close enough to drive to an alignment shop and the toe-out made the car unstable enough to notice and even trigger a stability control code for a steering angle fault.
cheeser
cheeser
Colorado
21 Mach 1, 4Runners and RAV4's
Took the Mach 1 for an alignment and found fronts with a bit of toe out:
Camber Left -1.7 Right -1.7
Toe Left -.08 Right -.06
Had Toe adjusted to .00 and camber remained the same for now and will monitor.
Also migrated to Continental Extreme Contact Sport 2s on front…will do rears in fall.
sk47
North Eastern TN
Jeff
Hello; Please check for recommended toe specs somewhere. I do not know what such may be for your car. Something I picked up somewhere over time has been to have the toe slightly IN. I do not swear by this but the reason as I understood it was the slight slack in the steering linkages would allow the toe to move out just a bit. I guess from drag on the road when driving.
But the alignment shops I use have the car specific specs in their shop.
Good luck
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
This is true. However modern cars do not have as many pivot points so this is less of a factor today. That said I still like a small amount of toe in. This has 2 effects. 1, like you said takes up any slack and 2, is more stable at high speeds.
sk47
North Eastern TN
Jeff
Hello; Having spent my early years working on vehicles with all sorts of links and discovering rack & pinion in the 1970's I see the point.
