FP Plugs vs Denso
BrianH87
Pittsburgh, PA
2020 Mustang GT ; 2021 Explorer ST
Does anyone know how the FP plugs m-12405-m50a stack up against the Denso ITV24? Are they different heat ranges? Or are they similar? Not much info on the FP ones. Only thing I know is Roush uses them in their SC kits. Whipple uses the Denso.
FreePenguin
Ohio
Donald
17 mustang
Chart them against eachother
Should tell you the heat range and type of electrode and material
If they are the same heat range and same electrode type, they are same plug. Just pick the brand you trust more
brianbr
Surprise
Brian
2019 Magnetic GT PP
Isn't the itv24 a non projected plug? I'm pretty sure it is. I had a set, even when it hot out it idled like crap, especially when the engine was cold. Might be ok for race applications though.
BrianH87
BrianH87
Pittsburgh, PA
My main problem here was finding the heat range of the Ford Performance Plugs. Took a while, but they appear to be 7, same as stock 2020 Coyote. So that's not going to work. It'll have to be the denso ITV24 or NGK 6511. I do believe the GT500 SP581 are another option that will work. Thanks for suggestions.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I run E3 but not a lot of people are willing to run them
Do they add anything? Longer life, better idle....... I see they are cheaper than the NGK's
Jackson1320
California
Jaxson
2015 mustang gt
They do better in testing but real life they seam to be equal to me in everything but price. They come gapped so they are a lot easier
K4fxd
NKY
7 dollars VS 11, I think I might try them.
illtal
a few weeks ago i amazoned them (E3.112) for 3.99 a piece.
