Ford Performance Oil Separator Loose??
quikcolin
Canada
Colin
2020 Mustang GT PP2
Hey guys,
Just installed a Ford performance passenger side oil separator on my 2020 PP2.
Install went smoothly, did everything by the book. Only thing that has my puzzled is how the separator itself is secured to the provided mount... there is a slot for the separator to slide onto, but it’s quite loose (up and down). The little tension put on it by the hoses won’t allow it to rest securely at the bottom of the mount.
The only thing I could think of was to zip ties it down to keep it from flopping up and down.
Anyone else encountered this? Seems like a strange design. They should have put a little rubber into the slot on the separator to hold it down fully seated into the mount...
2016 Mustang GT PP w/ Voodoo
Ya thats where it goes. Mine isn’t loose exactly, but its not hard mounted either, just the two hoses and that one plastic push clip. Its been fine that way for like 50k miles. Are your hoses clipped in right?
quikcolin
quikcolin
Canada
Colin
2020 Mustang GT PP2
Could you explain what you mean by “push clip”? Is it tight fitting. Or locking?
When I say loose. It fits into the slot perfectly, but it wants to sit high in the slot. Even without the hoses connected it’s quite sloppy (up and down). Then when you put the hoses on, it just sits about 1/2” high on the mount. Which can be pushed back down, but it pops back up. The zip tie keeps it down, but seems silly?
Meh its fine. Will do its job happily, just empty it every oil change and keep driving.
James1980
Poway, Ca
Jim
2020 Mustang GT
I ran into the same issue. Once the hoses are attached the separator would lift a bit. No matter how I adjusted it I would run into the same issue.
Like you, I used a zip tie to hold it down.
quikcolin
quikcolin
Canada
Colin
2020 Mustang GT PP2
That makes me feel better, thanks James! I’ll just roll with the zip ties 👍🏼
James1980
Poway, Ca
Jim
2020 Mustang GT
Mines been like that a few hundred miles. No problems.
Maybe after awhile the hoses will relax and we wont need the zip tie anymore
It sucks we have to do that. If there's something we're missing feel free to let us know. Wouldn't be the first time I missed something simple.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Hey Colin,
Mine was not loose like that. The bracket fit tight when the separator is pushed all the way down. On my bracket the powder coat is quite thick. Maybe Ford changed the design or didn't put the same amount of paint on it. The hoses can be manipulated a little. You can rotate the fittings on the tubes and adjust the gooseneck for a better fit. Try after the engine is warm.
Anyway, no longer using my bracket due to the FP tune and new throttle body.
I am still waiting for my custom made relocating brackets to come in. If they work out, I will powder coat them and offer them up for sale for those with the FP tune. The relocator will mount the oil separator on the passenger shock tower in the space just in front and below the strut brace. (will not work with the engine cover in place). Hopefully I measured everything correctly.
quikcolin
quikcolin
Canada
Colin
2020 Mustang GT PP2
Hey Colin,
Thanks Todd, yeah the mount and the slot on the separator are a loose fit. If the mount's powder coating was thicker, it would be a big help, but for now... zip ties it is hahaha
WD Pro
United Kingdom
Lime GT
Yeah mine rose up the bracket a little when new - I assume from the fit of the plastic hoses.
It didn't bother me as it wasn't touching the engine cover and the engine cover would prevent it from coming off the bracket anyway.
I think with heat cycles it's now relaxed a little anyway :like:
WD :like:
quikcolin
quikcolin
Canada
Colin
2020 Mustang GT PP2
WD :like:
I’ll check it out after a few more drives. I didn’t bother putting the engine cover back on, so lots of room in my situation 😬
WD Pro
United Kingdom
Lime GT
This was when it first went on :
I think that gap is a little bigger now and the separator never got high enough to touch the cover even when new :like:
WD :like:
James1980
Poway, Ca
Jim
2020 Mustang GT
@quikcolin Just thought I would update this in case you're interested
I kept the zip tie on until today. I took it off, emptied it and put it back. I did not need the zip tie this time, everything fit perfectly. So it seems my hope was correct, the hoses did relax and now everything is good.
quikcolin
quikcolin
Canada
Colin
2020 Mustang GT PP2
That’s great news!! Remind me, do you run with or without the engine cover?
James1980
Poway, Ca
Jim
2020 Mustang GT
I have the engine cover on, but I'm considering getting rid of it. It just gets in the way
