First look: JL audio system amp rack
Decible
Georgia
Sam
2023 Mach 1 HP
Decible
Georgia
Sam
2023 Mach 1 HP
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
I can sacrifice 1.87 I just cant give up 2.5+ 🤣🤣🤣
8W7s only require 1.0 cubes per sub. Surely you can do an underseat ported box for that size? If you do forward firing you can use round ports on either side or in the middle.
m3incorp
Georgia/Colorado
James
Well, I ran into another hick-up today. The crew goes to tune the system and for some reason no volume control works, not the one on the head unit or the steering wheel controls. I said the heck with it and made an appointment next week for them to troubleshoot/fix the entire installation and do the tuning. I will plan to leave the car with them for a couple of days.
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
What are you using for integration?
m3incorp
Georgia/Colorado
James
I have the PAC AmpPro AP4-FD21.
m3incorp
Georgia/Colorado
James
That could very well be the problem. I actually forgot to check if they were correct.
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Start there as that’s the first interruption to the signal path. Also, are you using the toslink or RCAs? If you’re using RCA make sure you have the output voltage set correctly. Some amps can’t take in 5V and if I recall that’s the factory setting for the dip switch. Also make sure the bass/chime knob is plugged in.
