dead_inside
I’m chasing false knock after install of a G2 kit and am curious if anyone could shed some light on a few things I’ve noticed. I will try to keep everything on target and provide data. I very much appreciate anyone’s time and experience, so just let me know if you would like pictures or more info.
Installed:
ESS G2 w/ G3 intercooler (125mm/6.5psi pulley)
ID1050x injectors
VMP BAP
NGK 6510 gapped to 0.028
Other engine mods:
FRPP passenger side catch can
Round 1 of logging: (Round 1 attachment)
92 pump gas
3rd gear pull from 3k to 6500
Round 2 of logging: (Round 2 attachment)
92 pump gas
Can of VP Unleaded Octanium
Round 3 of logging: (Round 3 attachment)
92 pump gas
6 gallons of 100 octane
Added padding between bumper and intercooler
3rd gear pull from 3k to 6500 (Had to let off early on log 14)
Steps I've done:
OEM headers and OEM exhaust but I've hit it with a rubber mallet just in case and heard nothing that sounded like rattling.
Made sure all clamps were not touching anything. Made note of precautions others made to prevent this and followed during my install.
Added foam padding between intercooler and lower grill insert. This appeared to make the most improvement. I had my only minus knock log after this change (log 13).
The knock is progressive, it’s always higher in the later pulls. I think that would be odd for a vibration causing false knock. Thinking about what could be different in the later pulls, my mind could only think of heat. So I made sure to let IATs and CHTs return to normal before logging the second and third pulls. No one else is reporting false knock with this kit, the silicon charge pipes were attractive to me about this kit for that reason. Tuner has asked if I want to disable the knock sensors and this is just a street car running pump gas, so I really want to avoid that. I will chase false knock until its resolved. I just want to make sure I am not overlooking something else.
Thank you to everyone willing to help!
Installed:
ID1050x injectors
VMP BAP
Other engine mods:
92 pump gas
92 pump gas
92 pump gas
Steps I've done:
