F&$#ing New Noise
Ahung12
Chicago
Al
2017 Shelby GT350R
Gonna throw out a wildcard in case it's not a wheelbearing: Is it possible that the rear diffuser or some other underbody panel somehow has come loose? If it only becomes noticeable above 35mph, it feels like it might have something to do with airflow around the vehicle, and a loose panel or flap may go from fluttering to vibrating to buzzing at speed.
galaxy
St Louis
'17 GT350
Thought of that too. Finally gotta get it up in the air tonight and get the wheels and everything off and start digging around. If it doesn't slap me in the face, gonna do a super great post road trip detail and take it from there. If the problem doesn't slap me in the face and it's still there after this work, I think I'll throw hubs at it and see. Or, like we used to say on the airplane "if you have a problem and you can't identify it, sit on your hands....it'll eventually turn into something you can identify", LOL.
galaxy
St Louis
'17 GT350
Welp, as my luck would have it - she’s up in the air, all belly pans off, brakes completely off…and I found nothing. The hubs, you just can’t spin fast enough to tell anything. I feel nothing in them and both sides feel the same. No debris or anything rubbing on a rotating part.
I’ll keep inspecting and update, but so far, no discovery. Woulda rather had it fall apart in my hand, lol.
I’m thinking I’ll do some serious cleaning, put it all back together, and then test drive. If it’s still there, imma throw hubs at it. 🤷🏼‍♀️
Timbuck
Australia
Tim
2017 s550 6r80
Wild card. On my 2017 gt I had a weird whrrrrrrr ing sound at speed and couldn’t hear it going slow. I to could only hear it at town speed or higher. It ended up being the OEM sticker on the tail shaft it had failed and was holding on one side , as you speed up and centrifugal force takes hold the sticker lifts out and whrrrrrrrrssssss against the underbody. Took me a few weeks to work it out because at rest the sticker looked normal. Fucking sticker. It sure sounded mechanical.
Mjc1241
Georgia
Reese
2016 Shelby GT350
I am in the same boat. I have a noise coming from the back of the car that is driving me nuts. Sounds like an old rocking chair. I have a Verus diffuser and a Borla atak cat back. I'm betting that it's either the diffuser or exhaust hangers. Either way, the car is headed to a shop soon to pull the diffuser down to check stuff out and hopefully track down the issue. Most of my rear suspension is aftermarket so this is going to be fun.....
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
A cupped tire will make a similar noise and will increase with speed. I’ve had that before. Give the tires a good check for any signs of cupping
galaxy
St Louis
'17 GT350
Well, with the wheels on it, can actually get a descent amount of spinning speed. Got my detailing done, car inspected, and all back together. Trying to spin the wheels best I could, the left (where I suspected the noise from in the first place) most certainly has a different grinding/rubbing sound compared to the right.
The car is up on a quick jack and those things are pretty solid. May crank it up and give it a spin in the air to see if I can tell. I hate doing that, but I’ve seen people full send it on quick jacks, sooooo!!
Worst case (based on time, funds, and don’t need the car), I may give her one more drive. If still there, screw it, I’m throwing new hubs on!
Mjc1241
Georgia
Reese
2016 Shelby GT350
Welp the new shop found out the noise issue or issues as it turned out. The groaning and creaking noise were remedied by simply greasing the sway bar bushings. I also bought new exhaust hangers which didn't need to be replaced but I had the shop do it anyway. My Verus rear diffuser was also re-adjusted to now have no clearance issues causing random exhaust rattles. Then we get to the good part. Long story short I receive a video last Thursday during the shakedown after a full test drive of any other issues that I might want to address and let's just say that the differential needed a full overhaul for corrective action. The same differential I had previously replaced about six months or so ago. Everything is all good now; no more noise and no more rear differential issues. Car drives like it should. Word to the wise; always get a second opinion if something doesn't feel right. My grandmother always used to say "go with your first mind" and I'm glad that I didn't let it go. I hope that you guys who are having similar noise issues that you are trying to track down, stay diligent to fully fix it.
