F&$#ing New Noise
galaxy
St Louis
'17 GT350
UUuggghhhh! So first off, I know diagnosing noises over the internet is futile at best. I just want to talk this outloud to make sure I'm hunting in the right spots using sound logic.
But I have a pretty darn predominant (and very new and distinguishable from existing noises) hum/buzz noise that's for certain coming from the rear end. It started out of the blue while cruising down the road on a road trip. It started 400 miles into a 500 mile drive almost like flipping on a light switch.
It is constant and it varies with vehicle speed and speed only. It does not change with any other factor. It does not change with any of the following; acceleration or decel rate, load on the engine, load on the rear axle/gears (on or off the gas), g-force, lateral forces (turning slow in a parking lot nor high loads like fast curves), clutch/engine engagement, gear selection, braking pressure or effort, etc, etc.
Again, it only changes with vehicle speed and it's hard to make out until 35+ or so.
I'm thinking it's gotta be something in a wheel assembly area; brake/disc related, hub/bearing, etc. And given the history on the car, I'm really gonna focus on the hubs. I hate to just throw parts at it. Wish sometimes it would just fail, lol. But just wanted to bounce the logic off you guys.
Eyesac
Reno NV
Isaac
2020 Mustang GT PP
I like you're Hub logic. Not a ton you can do to diag a diff from the outside (look for yoke end play, or drain and look for debris), but the hubs are quick, easy and cheap. My very first hub (of x3) failed on a 400 mile trip, gave me a light show on the dash and then went away. I couldn't feel any play in the hub in any way until I got down to the bare hub, then it was obvious. Also, I think I could do one it 45min if I tried, don't think you have to disassemble all the rear susp to replace!
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
Did you pick something up off the road that now rubs against a rotating part?
Kachow
Georgia
2017 GT350
Just had this. Car had 34k aprox on it. Would make a noise from rear around 50 mph.
Turned out to be right rear hub. Wouldn’t change like yours except at certain speed.
Also, the jiggle wheel test came out fine. At the shop they listened with a tool and it was easy to tell.
pilotgore
US
A bunch
Like others have said, I had a similar noise which I (for no apparent reason) thought was the rear end. Turns out it was a wheel bearing. Probably happened around 2,000-3,000 miles.
Unbridled5.0
NTX
2022 5.0 N/A, 2004 Mach 1 SC'd
If you have an infrared laser temp gun you can take it for a drive and then take and compare side to side measurements of various things and narrow it down. Whatever it is sounds like it's probably generating extra heat.
galaxy
St Louis
'17 GT350
Funny enough, that's the only thing I've done so far. And at the end of a 500 mile drive. No variances in tire, brake, center wheel/hub area. Great minds! I gotta get it up in the air next week and start digging.
JAJ
Vancouver BC
2016 GT350 Track Pack
I'm with @Mach VII. I think you picked up a bit of flotsam off the road and it's rubbing against something that's moving. No heat, sudden start, no variation with driving changes - it all sounds like a stick that's caught in the fender liner rubbing against the tire.
SheepDog
Colorado
Dax
Get a mechanics stethoscope from Harbor freight. Remove the wheel. Rotate the hub by hand while you listen with the scope touching the spindle near the bearing. You will be able to hear any sort of issue with the bearing that you wouldn't be able to hear otherwise, or that wouldn't show up on a wiggle test.
galaxy
St Louis
'17 GT350
thanks guys. All on the list to do. Gonna get it post road trip detail, then up in the air and start snooping around. Hopefully something jumps out at me, or falls apart in my hand. Will gladly take either one. Will keep ya updated.
stang17
Wilkes Barre, PA
2017 GT Premium PP
These cars, especially when lowered, seem to be very hard on the wheel bearings. I've replaced rear driver side 3 times and passenger side twice in less than 31k miles odometer. The most recent replacements have been with the timken brand ones and seem to be holding up fine as this is the longest (since new) I have had without issue.
HoldenSSVandGT350
Round Rock, TX
Brian
'14 Holden SSV Redline (Chevrolet SS sedan),
Had a similar scenario to this in an ‘04 GTO almost 20 yrs ago. All the same guesses as here. Swore it was diff related. Turned out to be the damn fuel pump. It did not sound like it could be the fuel pump at all. Now, anything like this coming from the diff area and I have fuel pump in the back of my mind. Good luck!
Evenmetal
Bay Area, CA
Steven
2017 Shelby GT350
Take the wheels off, do an inspection, and clean thoroughly. I'll get random particulates clogging the brake area sometimes creating noises. Check to see if your dust shield has bended and check pads etc. You'll find it.
dps
US
2020 GT350 Heritage Edition; 2021 GTS 4.0
Good descriptions - my vote is rear wheel bearing.
