EZ Spare
Free Spirit
pa
With my tires, the difference between the EZ-spare, in the front is less than a half of a percent, and the rear, is less than 3%. Torsen says the differential can handle a difference of 25% from a mini spare, as long as the restrictions are maintained. On a staggered wheel set, If having a front wheel as a spare works in a pinch, the difference with the EZ-spare is pretty much the same. Granted, you should never plan to drive on a spare, except getting to a spot where you can replacement tire. This difference is, IMO, totally acceptable.
Yeah but at the cost, you could get a full size spare and never have to worry about speed restrictions and short drives. You can drive in it indefinitely at any speed. I personally don't have a spare and if I bought one it'd be fullsize.
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2018 Jeep Grand Cherokee Summit
The issue isn't always about clearing brembos it's a about the overall diameter. A taller or shorter tire than the rest can cause the torsen in the performance pack to grenade itself
Everything I've found in the torsen says it causes issues,
No. Torsen says it's good for up to 25% across the axle, using a GT350 as the example case.
https://torsen.com/ask-torsen-using-a-mini-spare-tire/
But then you give up a big chunk of the trunk as a fullsize won't go in the well.
The AA spare goes in the well (barely, at 32 psi max, and sometimes with a bit of spray silicone as a persuader).
https://www.automotiveauthorityllc....-2015-2017-ford-mustang-gt-with-brembo-brakes
If im not mistaken the wheel tire from automotive authority is 27.5" so it would be a bigger mismatch.
It doesn't matter in the rear (see above) and the difference if on the front is not big enough to bother the ABS system.
luc
CA
2017 GT with PP
Good to hear if its over brembos. It looks like torsen stands by their differentials and use of mini spares because they have a statement on their website. Im assuming at under 27" it fits in the spare tire well with no issues?
I have AAA but really hate being stuck on the side of these dangerous southern highways for possibly hours waiting on a tow. Would like to have the ability to get off the highway quick or even drive to a tire shop if one is close.
What about getting a tire plug kit and a small cordless compressor?
I haven’t used a spare tire in over 20 years but have plugged many, many tires, both cars and motorcycles, on the side of the road in a few minutes..
Faster and easier than changing a tire
Just carry a pair of pliers to pry out whatever caused the leak
Free Spirit
pa
Ehhhhh. There's threads on here about a full size spare. You give up BARELY any trunk space. It pokes up just enough that the mat for the trunk won't lay 100% flat but it'll fit in the well and only stick up the smallest amount. Could always make a custom mount and lose 1 in of trunk height in a circle in the middle. 2 inches max if it's a 305
D Bergstrom
North Las Vegas, NV
Doug
2020 Mustang GT
When I first bought my 2017 GT back in 2017 I planned to get a full size wheel and tire as a spare. Bought the cheapest 19” wheel I could from tire rack. Tried fitting just the wheel in the trunk and it fit with no issues, but it took up a lot of room, and that was even before adding a tire. Returned the wheel and bought the AA spare. If you don’t want to use your trunk, a full size wheel and tire is fine, but want to use your trunk, a spare that fits in the well is the way to go.
Doug
D Bergstrom
North Las Vegas, NV
Doug
2020 Mustang GT
Not from my experience. Full size spare means diameter close to stock, so in my case, once a tire was on that wheel, it would have been a good 5 to 6 inches above the trunk floor. Even with the AA spare, I had to remove the foam on the back of the trunk floor to get it to sit flat, and even then, it is not completely flat. That being said, my AA spare is not a temporary spare, it has a load rating well above what is needed, and don’t recall the speed rating exactly, but it was certainly rated well above 55mph.
Doug
Free Spirit
pa
Doug
Not sure what to say. I can fit a 19x10 rims with a 275/40 tire with little to no issues with it sticking up or getting in the way. Full size spares are the only spares worth buying. Imo. Plus a patch will solve 99% of tire issues because chances are if it's a true blowout it's going to rip apart the fender or quarter panel and need significant body work to repair so it'll be getting towed.
D Bergstrom
North Las Vegas, NV
Doug
2020 Mustang GT
Do you deflate the tire to get it to fit? My AA tire is 27.5” in diameter, so just slightly smaller than a 275/40. As I mentioned, my tire sticks up slightly above the floor, a 275/40 in my car would stick up at least 6” above the floor. Only way i could get a 275/40 flush would be to take a BFH to the tire well and beat the crap out of it to expand it!
Doug
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
that doesn t always work depending on the tire damage but a possibility. In other cars I ve had that kit along with my spare.
Zooks527
The GT PP came with a compressor and sealant. Either the sealant or a plug works unless you get a side cut (my last flat on a packed interstate at rush hour), at which time you're toast.
Zooks527
.... because chances are if it's a true blowout it's going to rip apart the fender or quarter panel and need significant body work to repair so it'll be getting towed.
And when was the last time you saw this happen? In 50 years (this month, in fact) of driving, I've had flats, blowouts, retread delaminations, and more. I have never seen body damage at highway speeds or less on any of my cars or any friend's car.
KilluminatiDre
Was Chiraq now wonderful Arizona
2015 Mustang GT PP
Ive had valve stems fail on the interstate and the spare tire is the only reason i didnt have my day ruined. Thinking back to all the money ive spent on this car since 2015 i dont think $388 is much to have peace of mind and ability to roll my car.
DemonGT
Wisconsin
1991 Mustang GT, 2021 Mustang GT PP1
The AA spare also fits in the stock spare location under the rear carpet. I also bought a cheap little factory style jack and a lug socket with ratcheting breaker bar.
John S
Novi, Michigan
2022 Mach 1 HP
You could always go the DIY route with the 19" Kia/Hyundai SUV spare tire sourced from your local wrecking yard or eBay for significant savings. Exact tire sizes to match Mustang tire diameters are available and enlarging the wheel's pilot diameter to fit the Ford hub diameter is a breeze with a guided (double) hole saw. I did my Mach 1 HP with no problem fitting the spare in the tire well but my son's GT PP1 has a larger tire diameter and partially deflating the spare and silicone spray got it to nestle into the well.
