Experience with Motor Mount Replacement
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
Turbong
SoCal
2016 RR EB 6MT PP Recaros
So it looks like this is a common issue, shit motor mounts I assume? 63k miles mines are out definitely won't be able to do this job about how many hours to do this job?
NGOT8R
Adrian
2019 Bullitt
It’ll take about 2 1/2 hours to install the mounts.
mustang_puppy
Santa Rosa, CA
Juan
2015 black Ecoboost fastback
My reason for installing the mounts was for the improved handling via lowering the engine. I have read about the factory mounts leaking but didn't experience it.
Turbong
SoCal
It is quite more common than thought unfortunately, I found out recently fleet of explorers have had them replaced multiple times with low mileage, piss poor quality 0 durability.
Fokis
Az
Cory
2015 ford mustang v6
I used a scissor jack with a tree jack stand on top of it and a phonebook placed between the tree jack stand and the transmission to lift my engine for the header/motor mount installation.
I can't get the engine to raise up without the whole car raising. What do I need to unbolt... thx!
Fokis
Az
Cory
Sorry... to change the motor mounts. What am I not seeing.
NGOT8R
Adrian
2019 Bullitt
When I installed my motor mounts, I had the motor mount brackets off because I was installing headers at the same time.
You might still be able to remove them with the factory motor mount brackets in place though. Did you remove the nut on the studs at the top of both factory motor mounts and the transmission crossmember? That should do it
Fokis
Az
Cory
I didn't mess with the transmission. I just unbolted both front mounts and tried to jack it up. Thank you!
NGOT8R
Adrian
2019 Bullitt
Here’s a pic here to show which bolts will need to come out.
Fokis
Az
Cory
Makes sense. I was only using a small jack so I couldn't get under to see the transmission crossmember. I really appreciate it. It's my ex wife's car and I still keep it running for her. Thank you!
NGOT8R
Adrian
2019 Bullitt
Yessir! You’re very welcome.
TeeLew
So Cal
Tim
