ice445
- Apr 13, 2020
- Salt Lake City, UT
- Ryan
- 2020 Mustang GT 6MT
Sounds like the VCT/cam timing is dropping out. Surprising it's not setting a code, but apparently it often won't if it doesn't last for long enough or if the car dies.Yep, same problem here.. I have a 2020 GT manual with less than 13K on it. Granted, I also have a supercharger, header, full exhaust (no cats), and a tune.. But hearing it happens with stock cars AND modified cars is concerning.
Anytime I'm at a low speed, my car will potentially do this. Shifts fine and seems to have plenty of power for what I've got in it. No problems at WOT. But as soon as I go to slow down, on occasion, the engine will start surging and then quickly just shut off. I wouldn't call it stalling like poor clutch technique, but the car just.. dies. Happens when I push the clutch in and get into neutral. Happens if I leave the car in gear and stop with the brakes+ clutch, it's not easily replicable because it almost seems random..
Also happens just in slow speed operation, like in a drive thru. If I'm sitting still and I need to pull up, I'll put the car into first, let out the clutch and give it a little gas to get rolling, and as soon as I push the clutch back in it's like the RPMs just go crazy. In that scenario, they'll usually instantly fluctuate upwards violently 700-1k+ rpms whatever I'm currently at, then they drop down to 700 and start bouncing up and down between 8-400, then car shuts off. Or sometimes the car just immediately shuts off after the violent increase in RPMs.
I'm thinking it has to be the tune or something fuel related, purge valve/evap, throttle body/tps, fuel pump? My mechanic just took apart the whole engine basically to install a new oil pump gear and he inspected all gaskets and hoses and didn't find any signs of a vacuum leak. We thought maybe turbulent air from the way the CAI is set up, but I've pretty much ruled that out since it happens when the car doesn't have enough force to be sucking up excess air. Also kinda thinking tune, but when we first got the supercharger installed we had it dyno tuned and it ran just fine for the tuner and my mechanic who drove it back to the shop.
Rarely get codes, whenever I do it's for a rich or lean code and usually only one bank.
