Seesnax
- Jan 9, 2018
- South Central Ohio
- Chris
- 2016 EB Premium
With an automatic, and assuming you're controlling the shifts (via the paddles), do not underestimate your shift points: don't run it to redline at each shift. You want to shift at the point where the car will be in the power band of the next higher gear (plus, the engine seems to run out of steam as you get close to redline). On my 2016 EB (non-PP) automatic (6-speed), I hit the 1-2 shift at about 4800 RPM. This puts me right in the power band of second gear, which I can run up to 60 mph. I noticed several tenths difference in doing so (can regularly run off 5.8-5.9s 0-60 times).
Not sure what the shift points would (or should) be of the 10-speed, but I'm sure someone on here has some experience with the best shift RPM. What do you guys go through getting to 60mph, like 4 shifts???
