e85 on 2019 Ecoboost
Belalk
Flint MI
Belal
2018 Mustang GT PP1
Hey I'm thinking about running e85 on my 2019 ecoboost, it doesn't have any aftermarket mods other than a BOV. Other than tuning the car to run e85 is there any other mods I need to get in order for it to be able to run e85 with no problems?
77Highboy77
WA
Brad
2018 Ecoboost Mustang
Yep, you'll need an aftermarket fuel system whether it be a port injection system or an upgraded direct injection system. The stock fuel system won't support more than e30, so just a tune won't do it.
Coyote Chase
Don
2010/2018 Mustang
Will (E30) give you an advantage over the fuel your using?
"I've been told it burns cooler and may help with engine temps?? But the octane is about the same as (93) gas?? Don't know if any of this is true... Just something I read in a forum!!"
MiDiablo
#JustA4Banger
Spring Hill, FL
www.youtube.com
Josh
2018 Mustang GT PP 400A 10R80 RTR Spec 5 Widebody
Factory EBMs with only a BOV cannot run full E85. At best you'll be able to run E30-E40, after having bought a tuning device and tune, of course.
For full E85 you'll need a Cobb Accessport, a Pro Tune (we recommend PD Tuning), and either a Port Injection system or an upgraded HPFP from Nostrum or XDI, preferably coupled with the matching upgraded DI injectors.
We're happy to help you achieve your goals with your EcoBoost:
www.Facebook.com/ParkerPerformanceFL
Coyote Chase
Don
2010/2018 Mustang
What performance benefits will Belark achieve switching to E30/40 over using 93octane (w/tune)??
MiDiablo
#JustA4Banger
Spring Hill, FL
www.youtube.com
Josh
Horsepower. Torque.
Simplest of answers, I know. But E85 burns cooler, allows us to run more boost and more timing, safely. Can pickup between 30-50rwhp depending on existing mods.
Remember that delta going from stock to a few bolt-on parts and an OTS tune? This is a similar delta when going from 93 to
Coyote Chase
Don
2010/2018 Mustang
Horsepower. Torque.
Good information! Is it safe to assume that going from 93octane to E30 will produce about 1/3 the performance benefits of going all the way to E85 with reduced modifications to a mildly modified stock motor??
MiDiablo
#JustA4Banger
Spring Hill, FL
www.youtube.com
Josh
Probably more like 40-50% of full E85. Because anything north of about E70 we end up running the same fueling and timing typically. Unless on full balls race setup, then every point of ethanol counts and we may wring it out a little more then (so long as the fuel content allows for it).
shogun32
Northern VA
The timing improvements from a E30 tune are big enough to notice.
ihasnostang
MN
www.youtube.com
Saturn ion, 2019 201A, EB PP1, Ruby Red
not to threadjack but can some ethanol be blended in to a cobb OTS tune? Mainly for cooling properties and being able to maintain power for longer.
Coyote Chase
Don
2010/2018 Mustang
I've been running the Cobb OTS Stage 3, 93 octane tune with a shot of ethanol during the 2021 season. I add 2.5 gallons of flex fuel to 8 gallons of 93 octane pump gas. Results have been good! Lower temperatures and more power.
ihasnostang
MN
www.youtube.com
interesting i'll have to try adding some E. have you tested your pump e85 to verify its 85%?, calculating the mix shows about E28. Or even if its only 55% still nets E21
Coyote Chase
Don
2010/2018 Mustang
It tested at 71%
ihasnostang
MN
www.youtube.com
are you on stock plugs, or 1 step colder? if there a learning process, easing into heavy throttle? anything like fuel trims to watch on the AP?
