E85 check engine light
ZXMustang
US
2025 Mustang GT
i called and they said it’s normal for the check engine light it should go away after 50 miles the guy also said to switch to the 85
i called bama they said it’s normal for the check engine light after 50 miles it should go away and the studdering
Yeah no none of that is normal. You can clear the engine light and codes with your handheld scanner. Then drive it but I would be looking for a new tuner going forward.
hchf1234
Florida Fort Myers
Lucas
2020 Mustang gt 10 speed
can p2099 and p2097 blow my engine up?
ZXMustang
US
2025 Mustang GT
At this point you need to call your tuner, send them logs and demand they make this run properly. Or switch tuners. I cant answer that if what you got going on at the moment is going to blow your engine. But I can tell you it doesnt appear its running correctly. Please call your tuner and send them a log so they can correct this. Or fire them and get another tuner.
hchf1234
Florida Fort Myers
Lucas
so am i good to drive until it’s empty and go back to 93
chuckhammer
SC
Charlie
'22 GT, Carbonized Gray, MT82, base, no options.
Didn't know BAMA had a flex tune option these days. They only advertised 93 and E85 Race. When I found their bad reviews here on M6G they were nearly all for flex tunes on Gen 2 motors. Made me think they abandoned flex tunes.
hchf1234
Florida Fort Myers
Lucas
what tuners supports the bama tuner
chuckhammer
SC
Charlie
Shaun at AED uses the SCT X4. Rob Shoemaker, I think, as well. Some of the other outfits, such as Juggernaut and Ortiz may as well.
I agree with get rid of your tuner.
I would have to see actual logs to answer this. Looking at your video it appears it is running a bit lean 1.05 lambsa. It should vary from .98 to 1.02 or so.
Are you sure you are flashing the flex tune? If you can, pull up LTFT and STFT and put up another video showing those.
hchf1234
Florida Fort Myers
Lucas
Are you sure you are flashing the flex tune? If you can pull up LTFT and STFT and put up another video showing those.
it is for sure a flex tune and i can when i got to lunch what are the ltft and stft on my bama tuner
They are long and short term fuel trims. That will tell me more of what is going on with your car.
B1 and B2 You should be able to select these from your Bama tuning device. Replace spark advance and AFR with the LT's and ST's keep lambsa.
stannypack
NOVA
2022 Mustang GT
Don't think that's normal, I loaded Juggernaut's flex tune and datalogged with no issues or cels
