E85 check engine light
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
K4fxd
NKY
K4fxd
NKY
real Ford ECU integration?
Real integration. Their software allows the making of a custom OS so adding the sensor is a few simple steps. They have things like multi tune while the engine is running. Cool stuff coming.
ZXMustang
US
2025 Mustang GT
So do you need to pin it into the ECU harness then like the GM stuff?
K4fxd
NKY
This is about all I know about it right now.
K4fxd
NKY
I do have PCMtec software and am learning how to use it. It has much more than HP which I also use.
ZXMustang
US
2025 Mustang GT
So sick man. Im excited for this. Running an e blend with my whipple kit would be awesome to have this in real time. So much safer than trying to deal with a flex tune or trying to manually mix a blend on a straight E tune no matter the percentage. Thanks for the info.
K4fxd
NKY
hchf1234
Florida Fort Myers
Lucas
2020 Mustang gt 10 speed
It didnt have enough time to learn the E completely before the trims matured from the fill up, so the trims are way off (+20 to +30% most likely). You need to reflash down that flex tune again or do a KAM reset to trigger it to learn the ethanol content again. Once the E has gotten all the way through the fuel system, the AFR will start to come down around 10.0 depending on how good the E you got was.
Otherwise its going to run like this until you refill gas again to trigger a relearn. And its a certain amount or more, I forget what it is. Like 10 gallons or something you need to refill before it will trigger the relearn naturally... Someone correct me on that.
So bottom line, just reflash down that flex tune again and then let the car idle for like 10-15 minutes after. It will learn down the AFR and it will run like a beast. You can see the AFR going down on the gauge in the DIC.
should i always run a flex tune or switch to e85 only tune
abatman
Houston, TX
2015 Mustang Ecoboost
has anyone noticed that OP has an ecoboost which doesn't do e85 without additional hardware?
