headers and check engine light
hchf1234
Florida Fort Myers
Lucas
2020 Mustang gt 10 speed
just installed catless headers now i have a code for p0171 and p0174 is this normal? i am tuned by majed on base map
LOL WUT
Illinois
19 GT
Normal, you have no cats…. Get some 02 spacers (search the forum for big daddy spacers).
dcalero
2017 GT350 w/Tech Pack
That is normal, the o2 sensors readings are out of range since you removed your catalytic converter. I don't think a tune will fix it but i'm not 100% sure. You can add a defouler to each header which will make the o2 sensor be further away from the pipe.
hchf1234
Florida Fort Myers
Lucas
my tuner said he wants data logs i’m assuming because my afr were reading low and spikes randomly and drops i did the data logs and seems to be around 14 now
Zelek
Hutto, TX
2021 Mustang Mach 1
Tuners don't turn off rear O2's anymore due to EPA coming after them if they do. You need spacers even with catted long tube headers.
Zelek
Hutto, TX
2021 Mustang Mach 1
the code was for running lean guessing it’s tune related
Correct, you'd be getting P0420 if it was the O2's. Once you do some highway driving at a consistent speed, that's usually when you'll get that code.
hchf1234
Florida Fort Myers
Lucas
i did some data logs last night hopefully that fixes it so it’s 100% tune related?
Zelek
Hutto, TX
2021 Mustang Mach 1
Sounds like it is. Are you running E85 or is it just straight 91/93?
Zelek
Hutto, TX
2021 Mustang Mach 1
hchf1234
Florida Fort Myers
Lucas
You need to send a data log to your tuner.
i already did acouple idle for 5 min and a couple 2-7k rpm pulls and the light hasn’t come back on but i haven’t drove it a lot yet just trying to see if it comes back on then what could be the issue
