E85 check engine light
hchf1234
Florida Fort Myers
Lucas
2020 Mustang gt 10 speed
recently wanted to try e85. Requested a flex tune from bama and got my tank as low as 5 miles left filled all the way up with e85. Ran fine for the next 2 days then on the way to work i noticed when i slowed down the car would stutter and then i got a check engine light for p2099 and p2097.
ZXMustang
US
2025 Mustang GT
It didnt have enough time to learn the E completely before the trims matured from the fill up, so the trims are way off (+20 to +30% most likely). You need to reflash down that flex tune again or do a KAM reset to trigger it to learn the ethanol content again. Once the E has gotten all the way through the fuel system, the AFR will start to come down around 10.0 depending on how good the E you got was.
Otherwise its going to run like this until you refill gas again to trigger a relearn. And its a certain amount or more, I forget what it is. Like 10 gallons or something you need to refill before it will trigger the relearn naturally... Someone correct me on that.
So bottom line, just reflash down that flex tune again and then let the car idle for like 10-15 minutes after. It will learn down the AFR and it will run like a beast. You can see the AFR going down on the gauge in the DIC.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Those are codes for the engine running rich. Would need to see the logs to figure out what is actually going on.
K4fxd
NKY
Factory is set to 10% so 1.6 gallons should trigger a reset.
I tend to agree with your assessment.
ZXMustang
US
2025 Mustang GT
Yeah 10% not 10 gallons. I knew it was 10 something...lol
And yes its running rich like +30% trims from burning the E (9.8-10.2 AFR) but the car is trying to command 14.10 AFR... But technically its not "running rich". If the trims are not maxed out, then its running at commanded but also adding a ton of fuel to offset what its seeing vs what it was told it should be seeing. But its not "running rich". Its running at the correct stoich for E just really on the ragged edge with what it can correct for I bet.
ZXMustang
US
2025 Mustang GT
This is what it looks like in real time when I reflashed my car that was already on full E and it started the learning procedure from E10.
K4fxd
NKY
This is why I want to see the logs. I've never let my trims be out so long as to get a code.
ZXMustang
US
2025 Mustang GT
Agreed. But no offense to the OP, I dont think hes going to be able to get a log for us if hes using BAMA. I doubt he has HPT or the SCT equivalent to do logging that could be posted. I may be wrong, but I doubt it.
hchf1234
Florida Fort Myers
Lucas
i ordered one of those test kits i’m gonna test it when i get it
DougS550
Fishers, Indiana
Doug
Do the inline E85 sensor you install inline of the fuel line work? I think they are blue tooth?
K4fxd
NKY
Not currently supported but will be soon. Lund will be the first to get the system.
Lund might already have it.
ZXMustang
US
2025 Mustang GT
You saying it will work with the factory ECU and adjust AFR depending on E content? Like the LT1/4 cars do with E sensors?
K4fxd
NKY
Yes
DougS550
Fishers, Indiana
Doug
I don't want to use Lund, but I will install one
