Drag Racing Suspension Question.
rabid_josh
Columbus, OH
Josh
2020 Ford Mustang GT
Recently gotten to the point of a bolt on car horsepower range on my 2020 401A PP1 car w/magnaride. So 480-500ish WHP. I’m not going boost any time soon, and I’m looking for some answers. I run Mickey ET street Rs somewhere around the 16-17psi range, I’ve got vertical links and cradle lockouts. The car spins on marginal track surfaces at anything above a 1500rpm launch. I’d like to get into the lower 1.6s 60ft range without having to require radial prep. My only issue that throws a wrench into things is I cannot lower the car any further than stock magnaride height as my driveway won’t allow for it.
Best the car has ever went is a 1.71 60ft with less HP than current.
Any tips, part suggestions, etc are greatly appreciated.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Lowering isn't going to help, and would probably hurt. Lowering the CG means less rearward load transfer under acceleration = less instantaneous rear tire load = a bit less launch bite.
If there are any instant center/anti-squat modifications available for the S550, I am not aware of them.
Norm
rabid_josh
rabid_josh
Columbus, OH
Josh
Norm
I am not lowering the car. We are keeping the same ride height. I already know travel is your friend.
Norm Peterson
Norm
'08 GT #85, '19 WRX
Anti-squat is your friend here, not suspension squat.
Squat is not load transfer per se; it's only the visible evidence of rearward load transfer happening against a rear suspension that is neither rigid (and can't move) nor geometrically arranged to eliminate all or most of the squat.
Norm
rabid_josh
rabid_josh
Columbus, OH
Josh
Norm
Honestly the stock suspension appears to transfer fairly well. Its just not functioning now well enough, and this is seemingly the next potential step
