IPOGT
And don't forget European market requirements on the 2018+, which is why they are called Euro Mustangs.Those improvements were mostly about the EPA and MPGs. It was about emissions and fuel economy.
No, I've posted nothing incorrect, except CJPP 2nd link. Everything else is correct.Actually it started by you quoting me and then citing multiple incorrect numbers. So you seem to be REALLY bad at citing facts.
You started out by saying, as a fact, that the engine dyno that I mentioned was wrong and proven wrong "multiple" times. When I asked for proof you then proceed to show 0 information to back up your assessment. In fact you multiple times misquoted incorrect numbers, and then did so while even linking to the videos/articles that say different numbers than you stated. You also are not comparing STD to SAE they saying "its hyped numbers" as if simply using different correction factors are not a thing. Now you seem to not even know what engine dyno I'm taking about.No, I've posted nothing incorrect, except CJPP 2nd link. Everything else is correct.
What you've said, is that GEN3 Coyotes make 497HP, and all you're doing is going "you're wrong" without trying to post any substantiating information of your own.
Listen junior; anyone can jump in and point accusatory fingers at people, saying "you're wrong". That's bush-league. If you want to MAKE a point, rather than just accusing me of being wrong, then provide your own information that proves your point.
It's easy to tell people they're wrong, when you're not making the slightest bit of effort to prove your own point as the correct one.
Now; Show us proof-positive that 18 & 19 Coyotes make 497HP at the crank.
More "you're wrong and I'm right"......You started out by saying, as a fact, that the engine dyno that I mentioned was wrong and proven wrong "multiple" times. When I asked for proof you then proceed to show 0 information to back up your assessment. In fact you multiple times misquoted incorrect numbers, and then did so while even linking to the videos/articles that say different numbers than you stated. You also are not comparing STD to SAE they saying "its hyped numbers" as if simply using different correction factors are not a thing. Now you seem to not even know what engine dyno I'm taking about.
What about the fact that most stock dynos show ~420whp?More "you're wrong and I'm right"......
I'm questioning the 15% loss. Reading here I've heard more like 8% with new transmissions.What about the fact that most stock dynos show ~420whp?
Using a conservative 12% loss (420/.88) this means 477.27 crank hp.
Using a more realistic (for autos) 15% loss (420/.85) this is 494.12 crank hp.
And the real answer to all this Dyno back and forth is who F****n Cares !!!!!!!!You must suck at google as much as you suck at finding this mythical 385whp dyno.
https://www.hotrod.com/articles/ford-5-0l-coyote-dyno-test-cai-e85-tune-makes-532-hp/
497hp STD correction. Which is about 480 SAE. Stock calibration, 91oct.
Exactly.And the real answer to all this Dyno back and forth is who F****n Cares !!!!!!!!
I remember years ago when we got new patrol units in, all identical, there was always one of them that ran better than the others.My brother test drove 2 2019 GTs back to back at a dealership because he didn't think the first one was up to the advertised performance. The second was very noticeably quicker to him. He mentioned it to the salesmen and they didn't believe him so they took a ride, making sure the modes were the same, and they agreed to a man. I always hate to think there are significant differences from one identical car to another but in this case it seemed to be true. Take it for what it's worth... Might have been just in their heads based on what they were expecting to feel.
Agreed! The smartest guy is the one with the most Youtube links.........And the real answer to all this Dyno back and forth is who F****n Cares !!!!!!!!
Never understood why a chassis dyno can't calculate the drive train losses. When done with the run, just throw it in neutral and calculate the loss based on how long it takes for the drive train behind the clutch/TC to stop turning the drum.But this is all guessing anyways. Someone needs to remove the engine, exhaust system and ECU from an 18/19, and put it on a real engine dyno, to get the right answer.
