Direct injection pump question
Joshinator99
Massachusetts
Josh
2022 Mustang GT Premium, 2017 Camaro 2SS
DI cars often lower desired rail pressure at idle and light load because otherwise the injector on time would be too little and would make for wonky spray pattern.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
What are your fuel trims and lambda showing when it starts to act up and stall???
scoobaru88
19 Mustang GT
I’d have to recheck but I believe stft start going positive until it stalls, ltft don’t fluctuate at all.
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
Ay chance your tuner could send you a new calibration using only PI at idle for diagnostic purposes to see if it fixed your stalling issue?
engineermike
La
2018 GTPP A10
@bankf the stock tune uses 100% pi at idle. Sometimes I’ll run 100% di as a test, which may be in order in this case.
Cory S
Bradford, NH
Cory
So odd. One would think the DI would be much more suited for idle/cruise efficiency/control, and then port fueling coming in with a supplement for increased demand.
Joshinator99
Massachusetts
Josh
Your assumption is spot on and that’s why the 2019 LT5 Corvette ZR1 does fueling that way. But DI makes for a ā€œdiesel-likeā€ idle so many manufacturers don’t use DI at idle due to customer noise complaints. Lexus has been using port at idle and light throttle for years, and the PI comes in under enrichment. Plus using PI at idle helps make sure there is less build up on the back of the intake valves too.
engineermike
La
2018 GTPP A10
Di is for knock suppression but is worse in most other ways such as idle stability, valve cleanliness, and particulate emissions. As such, ford only uses DI at heavier loads when knock is most likely.
bankyf
2022 GT500 CFTP
That's right. I always get that backwards because it actually doesn't seem logical the way Ford does it. Perhaps his tune is running DI at idle, otherwise it seems pretty unrealistic that just resistance from pump alone would be enough to stall the engine.
bankyf
2022 GT500 CFTP
Interesting. I thought I had read that DI was much better for emissions.
engineermike
La
2018 GTPP A10
I believe the way they twist that these days is that di allows more compression which improves fuel economy which lowers co2 emissions…but it works in our favor so there’s that.
SilverUri
Poland
Damian
Mustang GT 2020
I’m leaning towards my direct injection pump is bad, desired pressure is 400psi, and it shows actual pressure is over 2000psi and creeps up to 2700/2800psi until car stalls out. No engine codes. Car just runs horribly and stalls out after idling for 5-10minutes.
Assuming new direct injection pump will fix the issue, but anything else that would cause this issue? Tuner says that the tune is fine. Ran on tune for 3k miles with no issues.
Hi
Have you ever figure it out what was wrong?
scoobaru88
19 Mustang GT
