Difference between a 4th gear pull & 5th gear pull on dyno
Detector
Dodge City Kansas
2015 Mustang GT Premium
I've seen where everyone says a dyno pull on a S550 GT manual should be done in 5th gear. What happens when you do a pull in 4th gear would it read higher or lower power/torque than it really has?
Thanks
TruBlu16GT
Castlegar, BC
Darrin
'16 Blue GT Base
4th gear still has a reduction ratio. 5th gear is 1:1 and will give the most accurate reading of engine output.
Detector
Detector
Dodge City Kansas
So a run in 4th would give a higher power/TQ reading or lower than 5th?
Thanks
P4RKER
Michigan
Alex
2015 Mustang GT Fastback
Higher
Keith_PDX
Portland, Oregon
2017 GT/PP
4th would have a mechanical advantage and theoretically show more torque than the 5th. Theoretically...
TexasRebel
Gearshifter
between the mustard and the mayo
2016 YZ GTPP - PP2
HP is calculated at the rollers by various methods (depending on the dynamometer type) and translated back to engine RPM to calculate engine torque. Gearing (4th gear as opposed to the direct drive 5th) only adds more unaccounted inefficiencies which would result in a lower value.
Automatics do not have a direct drive ratio.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
:confused:
That's a new one. Many do have a 1:1 ratio.....
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
From Ford
Optional Six-speed automatic with paddle shifters
Gear ratios
First 4.17
Second 2.34
Third 1.52
Fourth 1.14
Fifth 0.87
Sixth 0.69
The clutch & planetary system never directly connects the input shaft to the output shaft.
Strokerswild
Southern MN
Things With Wheels
Ah, yes, that particular automatic....I was speaking beyond the realm of S550.
Correct on the clutch/planetaries, but the gearing in an auto definitely comes into play in many aspects.
TexasRebel
Gearshifter
2016 YZ GTPP - PP2
Well yeah. That particular automatic is the only one in the S550.
Until recently, all automatics had a direct drive... It wasn't that long ago direct drive was the highest gear.
jrsimon27
Outside the USA
Mustang GT 2016 PP
I dynod my car one pull in 4th gear and another in 5th gear and the 5th gear pulled gave lower numbers like 10whp less
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
FYI for the '18 folks, the 10 spd is 1:1 in 7th gear, at least what's currently in the '17 F-150 and Raptor. I doubt it would change much, but it might.
