Diff Gear Swap
xr4x4ti
Minnesota
Tim
AWD 2017 Mustang GT 6MT Supercharged.
Is there an obvious go to company that can perform a gear swap in an S550 super 8.8? The shipping would probably kill you, but I want look into having somebody do it before I try it myself.
Thanks,
Tim
There should be many 4x4 shops up in mini-snow-ta. Find one with a good rep.
69mach1-395
central nm, usa
2016 RR GT/CS
Any real gearhead mechanic that rebuilds engines and transmissions most likely does differentials also. Check around town or talk to others that have had such work done...good luck.
AZlb5.0
Arizona
Carlos
18 GT Premium
Look for shops in town. There should be a solid one in your area.
Just purchase a loaded Super 8.8 rear pumpkin and swap the entire pumpkins - easiest thing to do instead of being concerned with shops, who's setting up gears properly, who's going to screw you outta $$$, or if the pinion was not properly loaded, etc...
The below link is just an example... search the many Mustang vendors for loaded 8.8's for brand new units.
https://performanceparts.ford.com/part/M-4001-88355B
Or if you can find a trustworthy salvage/recycler that sells a complete rear diff is another way to go. LKQ, Parts Farm and there's a few others to be found online that are reputable.
shogun32
Northern VA
what gearset are you targeting?
Steeda builds them all the time for in-house consumption. But it is a VERY expensive proposition.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
I did it myself. Easy peasy. But I have some experience in gear swaps. This one is no different than any other.
WD Pro
United Kingdom
Lime GT
I’m not saying this is good or bad, but at least it gives you a look inside to see if you want to tackle the job yourself :
WD :like:
xr4x4ti
Minnesota
Tim
Thanks for all of the feedback guys. It is more about saving time than pure ability or will. But, I think you all have convinced me to go for it myself.
Thanks!
Tim
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
Im looking to do same swap. It states fits "34 spline axles", do 2021 GT-non pp cars have these stock axles? or only PP cars. Will the swap require 34 spline axles?
Thanks Anthony
xr4x4ti
Minnesota
Tim
Thanks Anthony
All of the super 8.8's have the same spline.
All S550 mustangs have the super 8.8. The problem with the 3.15 is you need a different carrier or actual differential in order to run taller gears. Good news is they are cheap, last I looked around 250.
This.
https://performanceparts.ford.com/part/M-4204-M
