DCT Trans- same as C8?
Rubyred17
Kentucky
2017 GT350
Is our DCT transmission essentially the same as used in the C8? I am wondering because I noticed the Corvette C8 filter is called to be changed at 7500 miles (compared to our 20k miles). Plus, it looks as if GM has been experiencing some issues with theirs while ours appear to be much less problematic.
Just wondering....
JeremyPro5.0
CT
Jeremy
2020 GT500 & 2018 GT350R
From what I understand they are close but not the same.
They have another gear for one.
They are both made by Tremec.
Regretfully that’s all I got for you.
I’m sure others will chime in with much more info.
Snoopy49
California
Earl
2013 GT500 - SOLD and 2020 GT500 - SOLD
From what I understand the Corvette C8 DCT is a transaxle and the differential shares the same oil.
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
“The TREMEC-designed limited slip differentials feature spiral bevel designs that allow the entire transaxle to use a single fluid, allowing mass savings from a single oil cooler, pump, oil sump and filtration system.”
The Chairman
South TX
Just wondering....
I understand they are the same internals. They are both TR-9080. Somewhere is an announcement that they are building three versions: 7speed for the GT500, 8 speed for the C8, and an all wheel drive version. Presume this latter version is for the new Raptor-R.
Classic Lover
IL
2021 Dodge Challenger T/A 392 6 speed manual.
No way is a dct going into the raptor. At least I hope not.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Simple. It runs hotter.
The Chairman
South TX
Classic Lover
IL
Epiphany
Global
I like to disassemble things.
You could be right I just assumed they would beef up the ten speed. I don’t think a dct in a heavy pickup would be a good idea but who knows.
I going to have to agree with you. The cost of the DCT would seem prohibitive for using it off road when a beefed 10 speed might be better suited. Any kind of crawling is not going to get along with the DCT clutches at all. Then again, it's 2021. Everything is up in the air.
ICU812
Prestonburg,KY.
Ford Tempo, Ford Mustang,FFR,Crown vic.
Maybe Ford knows most of them will be mall crawling, not rock crawling
V00D00
Dover DE
2020 GT500
Close, ours is the TR-9070, hence 7 vs 8 gears
IPOGT
Alan
Watch how many start to bail for the C8.
Snakecollector
Central FL
Ron
'03 Cobra (sold), '08 Viper (sold), '20 GT500
Could have sworn our TR-9070 also had a higher torque capacity than the 9080.
