Crazy DSS DS Vibration at 60+mph
Genxer
2015 Mustang GT / Perf pack / DIB
What kind of janky machine shop do they have that something is .008" out?
I haven't had one of these Mustang driveshafts off the car. Do these use alignment pins or some kind of spline to keep them running true?
RedRoush17
Ma.
Gary
2017 Roush Mustang
Well I swapped the driveshaft 180 and still vibrates,Removing it and putting the stock one back in for now.
NGOT8R
Adrian
2019 Bullitt
Was your DSS driveshaft the latest revision on the market? Did you ever get the vibration issues worked out? I’ve been sitting on the fence about doing this mod. I already have a complete stop the hop kit and man car isn’t lowered. I love the stance on lowered S550s, but figured it would be best for me to leave it at factory ride height, so as to any potential problems.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
I wouldn't think that lowering the car would change the driveline angles on an IRS car, the pumpkin is mounted to the IRS subframe.
NGOT8R
Adrian
2019 Bullitt
I have no clue. It’s just an assumption on my part that it wouldn’t help things any with a one piece shaft.
RedRoush17
Ma.
Gary
2017 Roush Mustang
No I rarely drive the car,The stock one is still in it..Called DSS and they don't want to hear it..I am taking it to a local driveshaft shop and going to have them run it and rebalance if needed...If nothing can be done then tossing it in the trash.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Don't give up, check the driveline angles to make sure it is acceptable.
DeadSpool
DeadSpool
Fort McMurray, Alberta
2016 GTT
Not sure why but I haven’t been getting the notifications for this thread, so I’m sorry I’m so late to reply.
My Vibrations were absolutely horrible. I brought the shaft to the biggest local driveline shop and they said they couldn’t rebalance it because it needs a true high speed balancer, (8,000+rpm balancer) which very few places have and none in Canada that I’m aware of.
I was finally able to get a QA1 CF Shaft, threw it in and bam, no vibrations! Conclusion is the angles were fine, but the DSS was either twisted, warped or out of balance.
Never again will I use a DSS aluminum and have heard some shitty reviews from friends who tried thier CF. It’s QA1 for a pre made or get a PST CF custom one made.
NGOT8R
Adrian
2019 Bullitt
Okay thanks. I hope you get it sorted out. That’s terrible that DSS isn’t trying to work the problem with you.
ZZR
Toronto
ZR
'20 PP2 + '05 GT
Similar experience with DSS shaft in my S197 with Magnum trans. Drove me nuts trying to track the vibration down after swapping trans and shaft. Numerous calls to DSS, could have cared less. Had a local shop make me a new steel shaft, car is smooooooooth as silk. Expensive lesson learned.
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
Why do people still buy D.S.S products???
After threads like this and seeing one of their Carbon fibre shafts explode at the strip on an American Muscle video.
I can't help but avoid them. Other fish in the sea.
NGOT8R
Adrian
2019 Bullitt
NGOT8R
Adrian
2019 Bullitt
Did the local shop just use your factory forwards shaft and
differential flange to make the new driveshaft? Is it mild steed or chromoly? How much does it weigh?
ZZR
Toronto
ZR
'20 PP2 + '05 GT
Since the DSS shaft used a substandard yoke (which did not slide freely in the trans), I opted to all new using DOM tubing and all spicer parts. Keep in mind this was for an S197. Not sure on wt but can tell you it's impossible to imagine the car has even the slightest vibration afterwards.
