Coyote Black Oil Pump Gears
irmoviper
Argyle, TX
2018 Mustang GT Premium
Ordered these newly designed (past 2 months) OPG's from Boundary and would like to see if anyone else has installed them. I'm usually skeptical in ordering new things and I don't like to be a guinea pig, but Boundary has a solid reputation and is local to me and after speaking to Travis, I was reassured in my decision to purchase.
https://www.boundarypumps.com/ford-v8-cayote-1/coyote-black-oil-pump-gears
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Seems like a pretty cool design. I have the normal boundaries and they seem to be working great.
irmoviper
Argyle, TX
You may be one of the first few out there that are going to be giving these a try, i do say they are badass and you simply cant go wrong with Boundary in my opinion!
Guess I will report my findings when they are installed!
irmoviper
Argyle, TX
That is the general consensus I've heard. Had them in my Whippled GT350R and didn't have any issues. Will report findings when I have installed. I was told that the oil pressure is roughly 10 psi higher than the first version. We shall see
irmoviper
Argyle, TX
Did you order it with the anti-cavitation backing plate for the pump housing? i believe Boundary recommends getting that with the black gears.
Yes sir, I ordered it as well. They Said the reason they recommend it is because the black is a much harder material and it'll beat up the aluminum over time. So a martenWear finish on MartenWear finish is a tighter tolerance and better than MartenWear on Aluminum.
robertwsimpson
West Palm Beach, FL
Robert
2017 GT Convertible
Nice, I was wondering what the logic was. That makes sense.
zero_chance
Dismember
Arizona
JD
2017 GT Premium w/ Performance Pack
Don’t need them at all because I have the boring old regular Boundary gears.... but now I want those...
irmoviper
Argyle, TX
i honestly don't see the need to "upgrade" to these unless you get bored one day and have the time to do it! At least you have them in your car...
zero_chance
Dismember
Arizona
JD
You are 100% right. Zero need to do it. Means at some point I probably will. Will likely wait till I sleeve the block though.
irmoviper
Argyle, TX
Nice, hows the motor holding up with all that power? No issues? I'll take some photos and let you know about oil pressure and such when I get them installed. Doing Cams and ATI Damper at the same time.
zero_chance
Dismember
Arizona
JD
Zero issues, been supercharged for 20k miles now. Luckily, traction is still the weakest link, even with 305’s outback. Tires break loose before something major has the chance to break.
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
Digging this back up, anybody have first hand experience with this ported gerotor oil pump set yet? Also, I'm looking for info on their "MartenWear" surface finish, can't find anything. I'm guessing it's just a proprietary heat treat and tumble polish after surface grinding. Insight welcome.
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
Those look really nice. Not too many people running them yet but I'm sure we'll see more and more feedback as time goes on. We're running the regular Boundary OPG's in Goldmember and they've worked out great for us. It's the only engine mod we did on that car and it's held together for tons of 10, 9 and 8 second passes.
Anyone looking to pick up a set feel free to give us a shout. We've got plenty of Boundary in stock and are always here to help with any questions you may have.
https://www.lethalperformance.com/b...15-2019-gt350-2015-2017-f-150-2020-gt500.html
https://www.lethalperformance.com/b...l-pump-gears-and-camshaft-sprocket-combo.html
