Cooling fans turning on late
Jysl54
Georgia
Juan
2015 mustang gt
I’m currently fighting a cooling issue with my car where it will warm up as normal and stays cool while driving but as soon as I come to a stop cht reach around 232 and the radiator fans finally turn on, I’ve replaced the thermostat, and radiator fans all fuses seem to be fine as well.
DougS550
Fishers, Indiana
Doug
Have a tuner set the fan on to a lower temp
EFI
Masshole central
5.Br0
That's how they are in the stock tune, although unless it's like 120* outside it shouldn't get that hot just putting around.
You'll need a tune to lower the temps they turn on.
DougS550
Fishers, Indiana
Doug
And definitely make sure your radiator air inlet shields LT and RT are sealed as well as the lower air shield/deflector
HeelToeHero
Ontario
17 GT PP, 23 Elantra n-line
As someone mentioned this is normal due to the programming of the fans. See the table in this link: https://www.mustang6g.com/forums/threads/radiator-fan-temperature.165260/
If you're driving with the AC on, this sometimes helps keep the temps lower in stop and go traffic (because the fan will be on) unless you're in extreme heat. I used to see 110C regularly in around town traffic with no AC on.
Now with the power pack 2 I don't see over 96C in normal driving.
