Cooling fans question
Pucklord
Kamloops, BC
'17 Mustang GT California Special, '09 Mustang GT 45th Anniversary
Mustang GT 2017
I need to replace them cooling fans in my vehicle due to issues with the fan on the passenger side. However, I am uncertain whether it can be removed without taking out the entire radiator assembly.
Also I am curious about an alternative options to the OEM fans? Any recommendations would be greatly appreciated. Thank you in advance for your assistance."
Skye
ā‰ˆ39N
"Skye" Mach1 N2144
To orient myself as to what's involved, I watched the 5 minute video, above.
While the video highlights removing and replacing the radiator, it identifies how the fans attach to the radiator.
It appears you can access everything from the top side. After removing different assemblies, disconnect the electrical connector and two, 10 mm bolts near the top. With the fans now loose, the fan assembly can be pulled up and out. The assembly is held at the bottom by sliding the fans into their respective tabs. With the space available, it'd seems the fans can be removed while the radiator stays in-place. You might have to disconnect the upper radiator hose.
Point 3:40 shows how much space is in-between the fans and the engine. Point 4:15 identifies how the assembly detaches from the radiator.
Starting at point 5:00 in the following, the same can be seen:
Pucklord
Pucklord
Kamloops, BC
Thank you so much @Skye very informative much appreciated for taking the time to explain everything. It looks very easy to replace just the fans .. looks like its only the 2 bolts and an electric plug. Will see how that will turns out after buying the new fans.
Skye
ā‰ˆ39N
"Skye" Mach1 N2144
:thumbsup:
Regarding the best replacement options, the day is just getting started here. Those with experience could offer their feedback as to what worked for them along with possibly t-shooting tips to confirm it is the fan itself and not another item.
Pucklord
Pucklord
Kamloops, BC
I think I’ll stick with them oem fans! Been searching for an upgrade from ford performance but it seems that all 2015 - 2023 mustangs use the same fans! Thanks again
ORRadtech
Atlanta, Georgia
Use OEM fans. I don't know if there are upgrades out there but there are aftermarket ones. I recently had to replace the radiator fans in my Edge while on vacation. All I could get quickly were aftermarket fans. They fit fine and function properly but are considerably noisier than OEM. Since the Edge is our "spare" car I will leave them alone but if it were my DD they would greatly annoy me.
Johnny_ynnhoJ
Deerfield Beach FL
Johnny
2017 Mustang GT Premium
Hi Pucklord! did you replace the fans? I'm looking to replace mine because of the noise.
Pucklord
Pucklord
Kamloops, BC
Yup. Bought new oem fans. Replacing was straight forward and easy. Did it myself 30 mins max. Fans can be removed easily without the need to remove the whole radiator assembly.
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
Can individual fans be removed. Suppose you just want to replace one single fan?
Dana Pants
Burlington MA
Dana
2018 GT PP1
Another vote for ā€œuse the OEM fansā€. The engineering that goes into these things is beyond lay person comprehension.
Fun fact: the fan blades look like nuclear submarine propellers because the people who actually made nuclear submarine propellers started a company for automotive electric cooling fans many many years ago.
Anything aftermarket will either cool less or draw way more power and be way louder.
Unas2k5
Detroit
Samer
It would be hard to find fans that are better than the stock ones that fit
I’m saying if one Ford fan was bad can a single fan be replaced with another Ford fan? I was just wondering because I needed a harness and I found a fan assembly locally that had damage to the fan casing but not the fan and had the harness I needed. I ended up just buying a replacement harness on EBay.
