Cooler Retrofit Compilation Thread / Sticky Request
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
We need to hear back from Zombiekiller and SVTDSM ! Where are you guys ?
Tank
9/11 - Never Forget
Above the Notches
G0853
I opted to just go for it based on FP's last statement of "Fall" for cooler kits.
Today is in mid 80s here. My trans temps hit 225 degrees just driving around town. based on the wide delta between the operating maximum temp of the track pack trans at 165 degrees and my 225 degrees, i did not want to wait and risk longevity.
An excellent point often lost in the chatter....
SVTDSM
@Serpent_Stangs
Nashville area
2017 Shelby GT350R
I responded to you the other day in my thread. Everything worked out perfectly with my setup.
zombiekiller
warranties are 4 wussies
New Orleans
16 gt350, 66 galaxie,a Tesla, and an AMG G63
I've been home like 8 days in the last 6 weeks, so honestly, I haven't had the chance to start work on it.
It looks like my work schedule will relax a bit in the coming weeks, so i should get the chance to actually turn some wrenches.
thanks!
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
I responded to you the other day on my thread. Everything worked out perfectly with my setup.
Was just looking for an update . :thumbsup:
TDC
Long Island
2016 GT350, 2019 Challenger Scat Pack Widebody, 2019 Corvette Grand Sport
Bump to the top.
We all forgot about this thread and I am currently researching getting the bits to install the trans cooler. This thread if kept for its intended purpose could be an easy one stop resource.
I've been bouncing around all the threads gathering the excellent info available on the forum.
TDC
Long Island
Below is a list of Mustang 6G thread and post info to help us techies looking into an aftermarket solution (not necessarily the full transmission upgrade):
1st Tech Pack with Trans Cooler:
http://www.mustang6g.com/forums/showthread.php?t=49659
All non-Ford cooler part installation thread including home made brackets:
http://www.mustang6g.com/forums/showthread.php?t=83396
Aftermarket Coolers:
http://www.mustang6g.com/forums/showthread.php?t=58803
Discussion of electric pumps to use for tranny:
http://www.mustang6g.com/forums/showthread.php?t=64623&highlight=Trans+pump
RB oil pump website: http://www.rbracing-rsr.com/oilsystems.htm
2015-2016 Tech Pack and Base GT350 Cooler Solution Discussion:
WARNING - Thread below has a lot of info but it is huge and you have to navigate your way through trolls, whiners (me included) and disheartened Ford enthusiasts (some are now former enthusiasts):
http://www.mustang6g.com/forums/showthread.php?p=1568836#post1568836
Below is a complete kit for a Porsche but can be adapted:
http://www.patrickmotorsports.com/p...transmission-oil-cooler-system-trans-gearbox/
Ford Performance partial kit (no tranny):
M-7095-M8S
Link to Ford Performance partial kit cooler installation instructions:
https://performanceparts.ford.com/part/M-7095-M8S
Link to thread for retrofit Tech Pack to track pack. Includes great pics (thanks HACK) of how the Ford cooler and lines are assembled since the installation instructions above are lacking. Also includes instructions to install duct in place of block off plate.
http://www.mustang6g.com/forums/showthread.php?t=79125&highlight=Transmission&page=2
Ford cooler duct that replaces block off plate:
FR3Z-8310-F
Sprintamx
Mid-Atlantic
2016 Shelby GT350
A lot has happened since I started this thread last year, most notably that Ford "released" a partial transmission cooling package, and every other aftermarket possibility has faded away. And, it is now a bit easier to swap transmissions and install the factor cooling components, though there is still no OE solution for a differential cooler. There has been some exploration of the wiring harness and pinning out the correct power and sensor sources, but I don't think there's been a full solution posted yet. Maybe I missed it?
And, for what it's worth, I went ahead and fabricated my own cooling system in July 2016.
http://www.mustang6g.com/forums/showthread.php?t=58966
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
I plan on drilling and tapping the side port on the lower drivers side of the transmission for my pickup hose connection. I want to keep the fittings off of the bottom of the trans. Is there anyone else that has done this or considering doing this. I may start the install this weekend, I'll take pics of this approach.
Sprintamx
Mid-Atlantic
2016 Shelby GT350
I don't recall anyone doing the drill 'n tap, but there may have been some discussion about pros and cons in the various threads.
I concluded that the transmission is high enough in the tunnel that the line connecting to the OE drain hole is not in any great danger of ground contact. It's at least as high as the exhaust, if not a bit higher. But, that doesn't mean a different location is not a good idea.
Let us know how it works out.
Wine dude
Homestead
2016 Shadow Black GT 350
Since I am not technically inclined, my question is rather basic. If you replace the transmission and add the cooler, does it communicate with the PCM and do u have a view of the temp just like factory track does?
Side_Pce
NY
2016 GT350
The factory transmission cooler pump is not connected to the computer. It's a mechanical pump built into the transmission that runs constantly. You can enable the temperature gauge with ForScan on Tech package cars.
Tank
9/11 - Never Forget
Above the Notches
G0853
