Coolant type?
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
Is the motorcraft the only coolant use?
Is there any at the parts stores that will work?
Changing the T-stat and res so I figured it would be a good idea to have some on hand.
Thanks
Steven
vzwire
Nashville, TN
15 GT Prem w/ PP Hellion Twin Turbos
You must drain and FULLY flush out the orange stuff to use green.... But Green is fine.
I am running it on my 2015 GT with Hellion TT's.
Jay-rod427
Kansas
2016 GT C/S
Just buy the motorcraft. it's cheap easy, and works.
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
Jayme
DoggystyleRacing®
Baytown, TX
www.aedhp.com
Jayme
2015 Mustang GT
GM Dexcool works as well i heard.
SiMuL
.wise selectah.
Houston, TX
Jesse
2015 Mustang GT CO PP
Sounds like they're using something similar to VW's G12/G13.
You cannot mix that stuff with regular coolant, unless you want to sludge up your entire engine.
Olivas
Phoenix, AZ
Ernest
2015 CO GT w/PP
You're in Houston, just top off whatever you lose while doing the swap with distilled water + the coolant additive of your choice.
BlownGP
BlownGP
Houston/Baton Rouge
Steven
That's interesting.
I won't be using that stuff. I've GMs for over 20 years and Dexcool sucks. It's fine if you keep it flushed but it doesn't last long.
Thanks guys. I will use the motorcraft
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
For reference, when I did mine I lost about 3/4 of a gallon. I topped mine off with Distilled water. I'll check the freezing point sometime this summer and adjust accordingly if needed.
grabber yote
Corn Fed
Goldsboro, North Carolina
Grabber Blue 2017 GT PP
Buy the right coolant from the dealer. That's what I did when I installed my 170 t-stat
BlownGP
BlownGP
Houston/Baton Rouge
Steven
Yeah, I didn't think about that.
It doesn't get that cold down here, even though we did get snow twice this past winter.
I'm about 100% sure I won't be driving my mustang in anything below 32* anyways. lol
SVT-DADDY
World's heaviest S550
CT
2015 GT Convertible
^^^^^That's the thing to do. Base GT's have 13.6 qts, and PP cars have 15.2, so adding a gallon of distilled won't even get you to 75/25 which is preferred hot weather mix.
Water is much better at heat dissipation then coolant so it should benefit you nicely.
SVT-DADDY
CT
2015 GT Convertible
BlownGP
BlownGP
Houston/Baton Rouge
Steven
That's a good point.. Thanks buddy
