Coolant expansion tank adapter- pressure test
Deca
NY
17 GT350
Folks- got some tiny coolant leak somewhere so got a loaner pressure test kit from Advance. The yellow ‘ford’ cap fits perfectly, but pressure isnt building when pumping.
when using the generic rubber expansion adapter pressure does build, but afraid to pump it to 21psi as it already popped out at 3:-)
anyone knows? Specific adapter required?
thanks
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Deca
Deca
NY
17 GT350
Thanks - 100bucks😒 does that one have the universal quick connector?
I see now that the Advance loaner doesnt block the overflow hole...
Deca
Deca
NY
17 GT350
Got the stant 12043 adapter, but it is stripping the threads on this friggin plastic coolant tank- yours just screwed on smoothly? Also have the plastic tank still? Ty
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I’m using a Mishimoto tank now, but it worked on my OEM before I replaced it.
Do you have pics of it stripping/not biting the threads?
Deca
Deca
NY
17 GT350
The adapter being steel, it basically stripped/bit off small and thin threads/chips of plastic, like plastic hairs- don’t have any pics. Assume the adapter should screw on easily without any added pressure, right?
