Convertible latch difficult to rotate closed
BadHorsy
PA
2015 Ford Mustang GT Convertible
Is there a maintenance procedure to grease or lubricate the convertible latch? It seems like it’s a little hard to rotate it to/from the closed position. I can’t find anything online and I imagine it needs something silicone based perhaps?
Canadian Crimson
New Brunswick, Canada
Scott
2018 GT Convertible PP1 Royal Crimson
Not that I am aware of, although I do have to pull down on mine rather firmly to get it to latch at times.
S550HPP
PDC
2022 HPP Vert
Twice a year I cleaned (rag w degreaser) all weather strips everywhere and lubed with silicon grease. Better to use the lubes from Benz, BMW etc since they are non greasy easier to clean.
Just gotta pull and twist. I think is has something to do with out of adjustment tension cables which I believe are accessible from upper truck bulkhead couple little plastic pieces with rotating screws semi like the adjustors.
Johnnybee
Canada
2018 convertible
Mine was moaning a bit closing. So I sprayed all the hinges on the Fre
