Clunking in right rear after Pro-action install
blown302
ct
1987 mustang gt/2004 svt cobra/2016 GT PP
Had Steeda Pro-action struts and shocks [non adjustable] installed with minimum drop springs at Ford dealer and on the way home heard clunking over bumps in right rear. After checking everything for tightness and removing and reinstalling r/r shock and torquing fasteners still clunking. Installed stock shock on r/r and noise gone! Called Steeda and they want me to send shock for evaluation to see if it's bad. Has anyone else had a similar situation?
Drsmith33
Cincinnati
Donald
2018 Mustang gt
Most aftermarket shocks will cause some noise. Different bushings used. My Vikings caused a lot of noise once I installed them. Everything is probably fine. No need to worry
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Wut?
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
No issues here after 10k miles on ProActions and Ultralite springs. No noises at all, actually.
I’m curious to what the diagnoses will be; these dampers are really well built so it will be a big surprise it they are the problem.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Issues typically come from some part of the install, like tightening the mount on to the shock, if you use an impact you could kill the shock.
KewlWinter
Palm Bay, FL
Mark
2018 Mustang EcoBoost Premium+ Ruby Red
Another noise issue as a result of installing springs, struts and shocks is the spring isolator not seated properly.
blown302
ct
"]Another noise issue as a result of installing springs, struts and shocks is the spring isolator not seated properly.[/QUOTE]
installed stock shock and noise gone.
Drsmith33
Cincinnati
Donald
2018 Mustang gt
installed stock shock and noise gone.[/QUOTE]
Yes. As I said above, many aftermarket shocks will cause noise. My Vikings make a lot of noise but I don’t dd the car so I just live with it. If I did dd the car, then I probably would’ve went a different direction. Glad you found the source!
blown302
ct
Yes. As I said above, many aftermarket shocks will cause noise. My Vikings make a lot of noise but I don’t dd the car so I just live with it. If I did dd the car, then I probably would’ve went a different direction. Glad you found the source![/QUOTE]
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
[/QUOTE]
Please pm your contact info and we will get a replacement out to you. Make sure on install that the dealer does not spin the shaft when tightening with a pneumatic air gun. that's what usually damages the damper and it will cause knock back. The shaft needs to be held stationary and torqued to spec.
Thank you,
Steeda Tech
