Climate control actiing funky
Tmajikman
Michigan
Tim
2015 Mustang GT
2015 premium, I replaced the blend door actuator about a month ago because I was getting hot air out of the driver side and cold air out of the passenger side, once I replaced the actuator everything worked fine. I turned the ac on yesterday and now I am having the same issue, hot air out of the driver side and cold air from the passenger side. Is there something I have to do to reset the heating and air conditioner system? Is there something I missed when I installed the actuator? TIA
ORRadtech
Atlanta, Georgia
What actuator did you use? Ford or aftermarket? As crappy as stock actuators are aftermarket ones are often worse.
I hate to say it but I think your new one has failed. Though I suppose you could get lucky and the connector wasn't seated and backed out.
A couple of months ago I had to replace the passenger side one in my wife's '14 Fusion and there is no resetting of the system needed.
Tmajikman
Michigan
Tim
2015 Mustang GT
I used a Dorman, which I know they are the best but it was available at the time.
Tmajikman
Michigan
Tim
2015 Mustang GT
Thank you for your response and letting me know that there is no reset that is needed.
