pirates life
Does anyone know how the climate control on the premium adjusts temp? For example, I'm cruising on the highway in 80 degree weather, and I set the a/c temp to 70. Does the car turn off the compressor more frequently than if I had the temp set to LO, or does it modulate the temp by pumping more hot air from the engine?
My question is aimed at maximizing MPG, as I do a lot of highway driving. If raising the temp does not reduce compressor use, then using the temp seems a little inefficient, as opposed to keeping the temp on LO and turning the A/C on/off every 5-10 minutes or so.
The difference is probably negligible anyway, so just more curious than anything.
