Change oil without draining?
Nardly
Virginia
Bernard
21 Mach 1 Twister Orange M2425 Chassis
My wife went and had her oil changed in her Hyundai at Valvoline oil center and she was telling me that they removed the oil with a pump through the filler tube. I haven’t heard of doing it that way. To me it sounds half assed, possibly leaving sludge in the bottom of the pan. Is anyone changing their oil this way?
I do my lawn mower like that. Most cars that won't work due to not having a direct route to the oil pan.
sk47
North Eastern TN
Jeff
Hello; Two comments. First even an oil change thru a drain plug leaves some residual old oil in the pan for most cars/trucks I have worked on. May or may not be sludge depending in the vehicle. I have removed a few oil pans after a drain to always find some oil.
Second, I do the same for the automatic transmission of my truck. When i do an oil engine oil change I use a pump to draw some trans fluid out of the transmission. The pumps do work pretty well.
The only question is how much is left behind. If just a few ounces no big deal. If the oil change place is honest, they will have the actual quantity of new oil replaced on the ticket.
Hack
Minneapolis
Mustang, Camaro
When you go to a place like that, there are a lot of things that can go wrong. Be thankful they didn't cross thread the oil plug like happened on my 1970 Mustang. I learned my lesson and will never go to a quick lube type of place again.
I was in a hurry and stopped into one, they wouldn't let me out of my car. I said I watch or I drive off. I drove off.
Gnatsum21
Fort Lauderdale FL
Former: GT 21 Roush Twister Orange RIP | ECO 2016
I dont even know how my Ford dealership does it.. I just trust them. I pray that they change the oil to begin with and not just say the changed the oil and they didnt. 🤪
2022 Mach 1
Brentwood ca
Cameron
2022 Mach 1...2014 Mustag GT whipple supercharger
I've seen them suck it out of the dipstick tube as it reaches directly to the oil pan
James1980
Poway, Ca
Jim
2020 Mustang GT
I know that's how its done at Mercedes. Its called an oil extractor
It should be ok if they got enough out, they would know easily enough.
Not every car's dipstick has a direct shot to the oil pan. I know the F150 ecoboosts don't, there is a little channel is lives in.
If they're doing this regularly they probably have encountered all that before and know what to do. But that puts a lot of faith in a lube tech
boB
boB
2019 GT PP1
Afaik some Mercedes don't even have a drain plug (A220 does but no dipstick). Inboard boats are like this, ours had a drain plug but getting to it meant drilling a big hole in the hull! I went with the dipstick method. ;)
17Magnetic5.0
2017 premium mustang gt black accent package
I definitely understand your point but look at it from the perspective of who’s working on the car. I’m sure you wouldn’t want someone over your shoulder watching you work all day.
2022 Mach 1
Brentwood ca
Cameron
Correct. The dip stick itself sits in it own tube but the oil has to get into the tube at equilibrium of the oil pan somehow. Therefore it's logical you can drain oil via vacuum from this location.
Park
Mustang Ridge
Ken
2021 Mustang GT, 20 Mustang EB and 21 Bronco Sport
I have never heard of this 🤪
KeyLime
Pleasanton, CA
Lenny
2021 GT/CS Convertible
This is routinely done in marine engines where access to the oil pan is restricted by the bottom of the boat, engine mount beds or other structures.
Nardly
Nardly
Virginia
Bernard
That's what I was wondering, would it reach the oil pan. Was that on a 5.0?
