Catless with all monitors enabled
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
Hey guys I haven't looked at the o2's cause I'm still stock on that aspect, can someone tell me the number of wires on the o2 and what the colors are?
TheHydro
Las Vegas
2015 GT Performance Pack
I need to get my o2 sensors turned back on. I never knew the Lund tune turned them off. I have always ran cars with tunes and still passed emissions
area74
Canada
4dr
well....
here it is, you can have your cake and eat it !!!!
for off road use only of course !!!
catless and pass all monitors ! just like the BMW e90 N55 people.
this took us nearly two years to develop, it is not a simple fix, but it works and it works very well.
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
my friends car, not a mustang, has de-foulers on it. The CEL he gets now is not catalyst inefficiency. Instead it says secondary O2 sensor stuck rich. The best bet it to tune them off. His car requires sending the ECU off to flash it. I am definitely going to recommend an O2 simulator to him if he holds off on a proper tune much longer. Thank you Area74.
area74
Canada
4dr
well...it works like nothing ever before!!!!!! it is truly a smart sim....
it is a computer in itself !!!!
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
I've got spacers also. Still have the CEL
What style do you have? I had the 90* ones and they worked for me. Not on an S550 though so maybe no style spacer will work on this car
Yeah me too until IL changed its emissions standards a couple years ago. We were allowed up to two monitors to be "not supported". Now they all have to be ready.
area74
Canada
4dr
Hi all
would anyone be interested in testing this on an S550 ?
-you should have basic wiring skills
-a scan tool with the capability of checking readiness monitors
-document your progress good or bad
-an S550 catless, rear o2 sensors intact with no defoulers/spacers.
I will supply the sample and install help, providing you document installation and progress.
thanks in advance
sdmodified
New Jersey, USA
mkv Gti - stage 2+
So this will allow us to run long tubes and high flow cats and still have all sensors in a ready state with no check engine? If so, this is the perfect solution for states like New Jersey and New York where they have pretty stringent obdii scans.
Sent from my VS986 using Tapatalk
area74
Canada
4dr
You nailed it.......high flow, or none at all
OFF ROAD USE ONLY, of course.
Jonspeed
WA
well....
All your posts come off reminescent of a Nigerian scam. You seem shady.
Dolsvt00
Charleston
It can be fixed in the tune, and pass emissions testing with no cats or code. Most of the time tuners will disable rear o2 sensors effectively turning them off and preventing a CEL but if you perform emissions testing they will show up as not ready. You can leave the switch on, so that they will show as ready and remove the code so it does not show a CEL and it will pass.
2015 Silver GT
East Haven Connecticut
2022 Oxford White GT Premium
But then it will come up as N/A and if it's supposed to be a working monitor you will fail depending on where you live.
area74
Canada
4dr
Hi jonspeed
yes, I realize there will be a trust issue here, just check us out on e90post with N55 fix, just search catsim
I have also offered sample units for a tester for the S550, I merely hope to establish some trust, and provide a reliable fix.
Grim12
2016 GTPP
I thought this thread would get more attention.
What happened with this?
