Can you modify the Whipple Tune?
Palm Beach County
Nick
2019 GT
I added Longtubes, can a tuner modify the Whipple tune or do they have to start from a fresh base tune? What about if I added harness for IAT2 ? Can the Whipple tune read it?
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
I would probably go on to say start fresh. Unless you're tuner knows what they're really doing, I can't imagine Whipple's leaves their files open for edits like that?
IAT2 harness is for a custom tune. Since Whipple's are designed for their kits and what's included, I can't imagine they'd be able to add that. But, would be a question for their calibrators.
J17GT
IL
2017 Mustang GT PP
Yes, a tuner can modify the whipple tune if they are comfortable doing so. That's how my car is tuned today. Still running the Whipple OS, but tune is modified for what is done to my car. No, you can't change the IAT2 setup from how Whipple has it. If you do, then you'll need a complete retune on the Ford OS.
Southfloridanick
Palm Beach County
Nick
2019 GT
What are the disadvantages of using the Whipple tune as a base file ? If I swap my IAT back to the Whipple style set-up, do I lose anything ?
J17GT
IL
2017 Mustang GT PP
A tuner would be best to explain the pros and cons. Running the IAT2 harness the whipple way does not give you the opportunity to see IAT2 on your digital gauge cluster (it replaces the stock IAT1 info). You also can't log it with HP Tuners. If you are running the whipple tune, you must have IAT2 wired their way.
smokescreens
michigan
jason
2014 impala, 2017 HD. 2018 Royal C mustang gt pp1
My tuner modified the whipple tune as well. No meow's kooks. He tweaked the whipple tune to accommodate the long tubes, messed with the fans, ect. He is a pretty conservative tuner as he dont want you to grenade a motor. He claims whipple has a pretty decent tune overall but could stand a few tweaks anyhow. Mostly on fans he says. All in all i put 680hp to the tires on his dyno on 93. But the car pulled timing north of 4500rpm due to being octane limited on my gen 3 coyote. I cant bring myself to spend $4000 on a fuel system to run e85 i cant find at wvery gas station so.... 93 and a splash of boostane if i want to be silly
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
The Whipple tune can be easily modified by someone with HP Tuners. I don't believe it can be reconfigured to run an IAT2 harness, but I am not sure why you'd want to do that. The Whipple OS monitors both IAT and IAT2/MCT, and both be logged in HP Tuners easily.
J17GT
IL
2017 Mustang GT PP
I have not been successful logging IAT2/MCT with HP Tuners on my whipple tune. Is there a trick I don't know about? See screenshot below, it always reads some wonky negative temp:
**EDIT looking at a few old logs, it always reads -128*F
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
I have found using Intake Air Temp 2 works. Try re-polling for parameters and see if you have IAT 2.
J17GT
IL
2017 Mustang GT PP
I will have to look again. I don't recall ever seeing it. MCT was the only option I believe. Maybe something different with the 15-17 cars compared to the 18+ cars?
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
That could very well be. Also possible your OS might be defined incorrectly by HPT. They have a track record of doing that. A support ticket might fix it.
engineermike
La
2018 GTPP A10
There are pros and cons either way but the Whipple tunes does allow logging both iat and mct. Besides that they are largely the same. As others have said you can easily read and modify the Whipple tune just like stock. Most big tuners have one basic tune they like selling everyone and it works with a specific stock os so they just push that on every most customers.
HKusp
Hampton, Md.
Jason
Tim90NOS
LI, NY
Tim
2019 Bullitt Whipple
Recently acquired a 2019 Bullitt with a Whipple, I believe it's the 50 state legal version. Car came with no documentation, I am assuming it was tuned with the RTD from Whipple. I hooked my MPVI2 up and ran VCM editor, but I'm unable to pull the current tune. I set hardware to TC-298 and it says "Controller unlocker: Web exception, name resolution failure". I havent purchased credits for this car yet, but my understanding is I can pull the tune without credits. Am I missing something? Any help would be greatly appreciated.
Can MPVI2 pull a tune that was uploaded by RTD?
