Can't burnout on Whipple tune
RockStang
AA county MD
Joe
2016 GT Whippled
I'm at the track and the car will not let me do a burnout. Advanced trac is of course turned off. anyone else have a similar issue. FYI I went 11.0 at 128 with no burnout and a 1.58 60'
Getdownonit
George
2016 Ford Mustang GT Premium
Not bad for no burnout. Decent 60' times!
RockStang
RockStang
AA county MD
Joe
2016 GT Whippled
I put the selector in S this time and it worked fine.
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
You should be able to do a burn out, turn traction control off , hold button for a couple a seconds,in case you didnt
RockStang
RockStang
AA county MD
Joe
2016 GT Whippled
yeah something is wrong with it. I'm going to reflash the tune and see what's up. If the selector is in D it's like advanced trac or traction control is stuck on even though it says it's off. Even on the street I can only do a very slow spin. Like 1500 rpms. Won't go over that. No biggie putting it in S for now.
ETCH
San Diego
Rich
2015 Mustang GT Performance
Shit, im freaking firing the tires off mine and im not even trying.... yeah something is wrong.
sigintel
Ray
2018 GT
Fixed?
You using line lock?
Hold ok to init.
Then press brake real hard and maybe even pump brake pedal once or twice to get pressure high enough to engage.
Timer should start for burnout.
Nice 60 foot!! NT555R?
10.x in your future.
daltron
Rowing All Day
California
Jonathan
2016 GT PP
Easy way to see if TC is off: enable launch control. If it says LC, TC is on. If it says RPM, TC is off. Turning off Advanced Trac (aka holding the switch down) does NOT turn off TC.
Or just do what I did and take out fuse 62. No more nannies!
v8ter
Typing...
EL PASO , TX
Or just do what I did and take out fuse 62. No more nannies![/QUOTE
Holding the switch does not turn off tc? Why does it let you roast the tires then?
daltron
Rowing All Day
California
Jonathan
2016 GT PP
I was told turning off AT turns off everything, but I believe some form of the nannies must be on because LC is still enabled which is disabled if TC is fully off. Either way, I solved all that with fuse 62 out.
