Camber settings
RyanR3KC
Johnston, Iowa
2018 Camaro SS 1LE
OK...excuse my ignorance here...but does that owners manual discuss the steps to adjust the camber? Is this something that can be easily adjusted in the garage with just a couple tools?
I've never tinkered with camber before. Didn't have to mess with it in the 1LE.
tdzee
Atlanta Motorsports Park
Tom
85 Corvette, 04 Corvette Z16, 08 350Z NISMO, 15 CTS-V Coupe, 17 GT350R
OK... adjust the camber? Is this something that can be easily adjusted in the garage with just a couple tools?...
Not really a DIY thing. While it can be done by the experienced, you really need the machines to know all the settings are correct. Good luck. :thumbsup:
honeybadger
Just don't care
COTA
Kevin
'17 GT350
How handy are you? It's doable with a good tape measure, string, jack stands, a weight, and a bit of patience. It's also much easier with a camber/caster tool. I use this one from Longacre. You'll also need camber plates (such as Vorshlag, Maximum Motorsports, etc.) or BMR's camber bolts.
All depends on the user. I adjusted mine the first time with string and a tape measure. I was bang on when I got the alignment checked later!
honeybadger
Just don't care
COTA
Kevin
'17 GT350
So if you set it. This is still good for normal street driving correct?
Depends on where you set it. -1.75 is the minimum I'd set for an experience track driver that wants to maintain a street friendly camber setting. -2 to -2.2 is a good compromise if you want to focus on track use and are OK compromising longevity of tires on the street. I would not drive -2.4 or more on street unless you're fine cording the inside of your tires way before the outside.
rushca01
FW, Indiana
GT350 Oxford White OTT
I installed vorshlag camber plates and ford performance springs, would love if someone can post step by step DIY old school tape, plumb bomb etc...the camber plates make it pretty easy to adjust.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I'll grab some pics tonight and post a step-by-step!
