CAI without tune
angelpalomino
Angel
2017 Ford Mustang GT
I have a 2017 5.0 and recently installed a PMAS cold air intake (tune required) but have not tuned it just yet. I tried starting it after the installation but it would idle super low and then die out. Could this be just because there is no tune just yet or could there be another reason?
905Shooter
dallas, tx
Jake
2017 pp mustang gt
Yeah its most likely due to no tune the CAI would change airflow over the mass airflow sensor leading to those symptoms, just to be safe i'd take of the old intake and put the stock one on to see if it still is idling low and dying out. :thumbsup:
NeedForGreen
2019 Mustang GT
100% the fact there's no tune. You have a wider tube pushing different flow of air across the maf. It throws everything off.
boB
boB
2019 GT PP1
At idle the engine is pulling in the same amount (mass) of air that it did before. I can't see where the pressure drop of the stock air filter/intake vs the new filter/intake could be significantly different at the low volume of air the engine pulls in at idle.
I would look for something else like a vacuum or other line/wire misplaced/loose.
EFI
Masshole central
5.Br0
But it's not, because MAF size changed...so it's pulling more amount of air. If it was a no tune required intake, then your statement would be true. That's why intakes that change the MAF size require a new tune because more air is incoming and the ECU doesn't know what to do with it.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Get a tune. The car dying is 100% normal.
Andrew@Lethal
West Palm Beach Florida
Andrew
It will do that if you do not have a tune for a tune required intake. It flows way more air than the stock MAF calibration is used to and will cause your car to run funny and surge.
boB
boB
2019 GT PP1
My mistake, I thought the MAF had stayed the same. Yep, different MAF = new tune.
