Adam the Lighting Guy
- Jan 8, 2024
- West Palm Beach, FL
- Adam
- 2021 GT Convertable , California Special & 2020 Ecoboost Premium Coupe
I'd recommend a small butane torch. Pin point flame.I was thinking the same thing. Propane torch, needle nose vice grips as a first attempt. If that fails to turn without chewing up the screw, get a dremel with cutting wheel, cut a small notch, heat it up again and use a 3/8" ratchet with a flat nose screw driver attachment.
Just make sure you apply the heat around the bolt, not directly to the bolt. Typically they come out like butter unless it was cross-threaded then you're going to be forced to take everything apart and drill it out.
Tony
