Broke driver side axle
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Is the GT350 left side axle the same as the GT?
Dana Pants
Burlington MA
Dana
2018 GT PP1
It’s different but not appreciably stronger. The CV joint is a failure mode and the gt350 cv joint is the same size.
K4fxd
K4fxd
NKY
K4fxd
K4fxd
NKY
Thanks.
MiamiGT350
S. Florida
I would be careful about buying a used or take-off GT350 half shaft. I have seen a fair number that leak CV grease from the factory due to a bad seal. I had mine replaced under warranty.
K4fxd
K4fxd
NKY
I can always replace the grease and put a new clamp on it.
Honestly it only needs to last till Feb or so when I will get some real axles.
The stock GT axles are hollow. :crazy:
Are the 350 axles also hollow?
NGOT8R
Adrian
2019 Bullitt
@K4fxd are you getting into drag racing? What was the cause of your broken axle and what will you be switching to in February?
PickleGT
Wisconsin
2017 Ford Mustang GT
check fb marketplace place and hope for a good local deal i found a set of GT axles for $50 while i waited for my gforce to arrive
K4fxd
K4fxd
NKY
Too much abuse I guess. My car hooks so no wheel hop.
Not sure what I'll put in, I'll see what Terry has and go from there.
