Caballus
- Jan 24, 2016
- Over Yonder
- GT350
Why did you decide to go with Caliperfexion?The economics is pretty good actually. Stainless on aluminum will corrode to produce a fine white powder. Geomet, the coating on the OEM bolts, won't do that. They're not as corrosion resistant as stainless, but they're much better when installed in an aluminum fitting that's exposed to a corrosive situation, like road salt and water.
Second, they're not anywhere close to torque to yield - they tight, but that's all. They're single-use because the thread locker coating gets damaged when they're installed. Ford wants you to use new bolts with new thread locker.
Lastly, I removed and reinstalled my OEM bolts three or four times before I switched to Caliperfexiion studs. They're fine. Between the Geomet and the thread locker, there's no galling or damage.
