Boost gauge accuracy question
ToxicOverwatch
Oklahoma
2017 Silverado- extremely stock
Hey guys I admittedly am not incredibly educated on the most accurate way to measure boost via in car gauge. The Ford performance cluster that is compatible with performance pack cars is an attractive option as I can keep a factory appearance. Are these reasonably accurate?
Thank you in advance guys.
engineermike
La
2018 GTPP A10
They are exactly as accurate as the speed density model and maf transfer function in the pcm calibration.
Angrey
Coral Gables
2016 GT350
Does anyone make a pressure sensor with sending unit (physically measured at the vacuum source in the engine bay then electronically sent to a display unit)?
I'm sick of dealing with lengthy vacuum lines through the firewall and whether they're kinked or restricted.
Zrussian13
Phoenix
Like Mike said, as long as the calibration is good it should be accurate. I run this in my car along with an eboost2 and it's always been within 1psi of the eboost. I wouldn't rely on it for boost readings but it is way nicer to have a boost gauge in a boosted car than vacuum only.
LOL WUT
Illinois
19 GT
My AEM X series uses a pressure sensor with sending unit. Its tapped directly into my vacuum block.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Want accuracy ? Put a mechanical boost gauge in it.
