BMR CB005 issue
BCGT
Canada
15 GT
OK .... Just to sum up in my case: washers are OK and I should wait until you've completed analysis to see if a solution (ie shim plate) will be available for those of us with this issue.
Sounds good to me and I look forward to revisiting this in a few weeks.
Dragster
2015 GT PP
I've got mine ready to go, but I'm waiting on my rear sway bar to get here this week so I can do them both at the same time. I'll let everyone know how it goes. I've certainly had a good experience with Kelly and BMR so far!
dubster99
Nor*Cal
2015 Ingot Silver GT PP
No issues here either.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
dubster99
Nor*Cal
I also used the steeda subframe alignment bushings at the same time...that may have played a part in mine lining up better.
Jmeo
You said member ;)
Massachusetts
Jaime
What happened for me and a few others is after the front passengers side subframe bolt is tightened there was a gap between the arm and the body of the car where the two bolts attach to body. No given reason why this happens for a few of us but the alignment bushings are not the cause. I only put the bushings in the other day and the gap issue was there before I did this.
moarhorsepower
Jay
2015 Mustang GT
So would the best be get the CB005 kit and pair them with the Steeda subframe alignment kit? Was thinking this plus pair it with the BK054 differential lockouts
Jmeo
You said member ;)
Massachusetts
Jaime
Absolutely get CB005. I suggest you use with the alignment kit to, why not it's $30 ish and guarantees subframe alignment.
Diff lock outs will only further your anti wheel hop needs [emoji106]
dubster99
Nor*Cal
Anybody else notice a slight creaking noise from the right rear after installing this? Only happens when taking off normally from a stop, for a second or two when the clutch is being let out. Almost sounds like the rear interior decklid moving around or something. Sounds a little like a tire rub, but I know it's not that.
John S.
Valrico, Florida
2015 GT Premium Performance Pack
Mine just came in today. I'll install tomorrow.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
HAHAHAHAHAHAHAHAHAH!!!
John, come to the track tonight (BMP) - bunch of local Mustangs are going, and I will be running my '15 as well. ;)
John S.
Valrico, Florida
Man, I'd love to go. I haven't been to BMP in about 11 years. Unfortunately tonight wont work for me but I will definitely try next time. :cheers:
