Best subframe brace for convertible?
mustang123
SD
2019 Mustang GT Premium Convertible
Hi friends! I have a 2019 GT premium convertible (no PP or magneride). I like to drive canyons and mountains with the top down. The car handles reasonably well around sharp corners, but I do have quite a bit of body roll and brake dives. I already ordered some stiffer springs but was also wondering what kind of subframe braces I can add to make the car even stiffer? I saw that Ford already installed a strut tower brace under the hood, there's also a massive rear subframe brace from the factory. What are some good braces I can add that will not interfere with the factory brace?
Thanks for your suggestions!
Sigster
Alpharetta, GA
Sig
2023 Mach 1
Hey Mustang123. I'm was in the same boat. Steeda's Comfort suspension, which is progressive lowering springs and active struts/shocks, fixed all those problems on my non PP 18 GT convertible. Wow what a difference. The only thing I would do different is add the quarter inch spring spacers, because the back is heavy and a little too low because of that bracing you mentioned. The spacers would fix that inexpensively. I have enjoyed this setup for about a year, and am now getting ready to add some of the other cool suspension bits that Steeda offers, to take the car to the next level. But what I bought is I think the biggest initial bang for your buck. Do the shocks/struts at the same time as springs, you'll be happy you did.
pardoneo
Spain
Ex-'16 Mustang EcoBaby // Current '16 GT Convertible
I have just ordered Steeda Gtrac K brace and jacking rails to stiff up my EU PP vert.
I did installed the FP Strut Tower brace (from the GT350R) but it is barely noticeable on normal driving...
Copperhead73
Knoxville, TN
Derrick
2019 Mustang GT Premium Convertible PP1, A10, Mag, B&O, A/E, S&S
I did this to mine when I first got it. I did the J&M Jacking rails and Steeda G trac K Brace.
There is a little cowl shake on "washboarded" surfaces, but I am very pleased. Unfortunately, I didn't really get the chance to "before and after", but I would do the same mods again. The Gtrac K and Full length jacking rails are really no-brainers. They are cheap to buy and easy to install in the driveway. If you want to get a shop to install them, I suspect you can get it done for less than $100. The convenience the Jacking rails provide when lifting the car are worth it alone!
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
So with a PP1 car, this behind the factory K brace right? i.e., they can both be installed together[?]
Copperhead73
Knoxville, TN
Derrick
Correct...nothing had to be removed to add the GTrac K brace.
And LOL at your updated Avatar...
Johnnybee
Canada
2018 convertible
This is installed underneath and ties the bottom together better. Unless you’re not talking about the brace from the firewall to the top of the strut towers.
Shawn2018GT
Denver
Shawn
2018 Mustang GT 401A Auto
People get confused on the K brace. There is a bottom K brace that ties the front suspensions together. There is also a Ford Performance K brace to go along with their strut tower support brace above the engine. The lower braces have at least 3 different styles, all easy to bolt on.
The jacking braces should have come with the car. You have to get the convertible jacking braces, as the underside is slightly different from the fastback.
WILDB
Australia
Will
2017 GT convertible Oxford White
The BMR subframe brace made a big difference to my vert when paired with some jacking rails.
cbrookre
Ridgefield, WA
2015 Mustang GT Convertible 50th app
I just installed the jacking rails, but cannot drive for a few more months. So painful having it in storage!! :crying:
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
Subframes from either BMR or Steeda will help strengthen GT vert front ends. I have the simple Steeda bar.
CVCashmere
CVCashmere
South Jersey
Carl
Does it make sense to install a PP1 bottom K brace on standard Ecoboost vert?
You could the more bracing...the better. There are also articles on it. There is a flap to change your oil. I have one on my GT.
4-point bracing from Steeda and others may be able to substitute for that K brace.
CVCashmere
